Offset question
Results 1 to 12 of 12
Like Tree3Likes
  • 1 Post By flying fossil
  • 1 Post By RicktheRealtor
  • 1 Post By Lifer
Cadillac XTS Forum Discussion, Offset question in Current Cadillac Vehicle Discussion; Just picked up a 2013 Platinum XTS! I wanted to change the wheels to give it a bit more aggressive ...
    mugsy415 is offline Cadillac Owners Member
    Automobile(s): XTS
    Jul 2013
    39
    Offset question
    I wanted to change the wheels to give it a bit more aggressive look.
    MY QUESTIONS: I wanted to know whats the proper offset for 22" wheels staggered. Also whats the largest width can I go in the front and rear without rubbing. AND the proper tire sizes for the front and rear?
    Thanks in advance!
    flying fossil is offline Cadillac Owners Member
    Automobile(s): Kinda Red XTS Premium
    Oct 2012
    Irvine, CA
    76
    Re: Offset question
    Your local tire/wheel store has all your answers.
    ddawson is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 CTS PREMIUM SEDAN 3.6 RWD
    Oct 2007
    1,019
    Re: Offset question
    Quote Originally Posted by flying fossil View Post
    Excellent answer. This says it all. The end.
    Automobile(s): XTS
    Jul 2013
    39
    Re: Offset question
    I might want to buy from ebay or craigslist. which I do 99% of the time
    Oct 2007
    1,019
    Re: Offset question
    The answer remains the same.
    Oct 2012
    Irvine, CA
    76
    Re: Offset question
    Quote Originally Posted by mugsy415 View Post
    Best of luck to you with those sources.
    cardio-doc likes this.
    RicktheRealtor is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS Lux III
    Aug 2004
    Calgary, Alberta, Canada
    62
    338
    Re: Offset question
    It's not just a matter of "fitting" the tires into the wheel well. Anytime you modify wheel/tire size from the original, you start messing up speedometers, ABS calibrations, and especially the front suspension. I'd think hard about doing it to a premium vehicle. My two cents.
    Lizbill likes this.
    Lifer's Avatar
    Lifer is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 Cadillac Eldorado ETC
    Apr 2007
    Coppell, TX
    905
    Re: Offset question
    Roger that. The wheels that came with the car were well thought out and TESTED for handling and ride. Many other components rely on that wheel and its size. Don't mess with success.
    Lizbill likes this.
    Oct 2007
    1,019
    Re: Offset question
    The end.
    cardio-doc is offline Cadillac Owners Fanatic
    Automobile(s): 2009 DTS Performance
    Feb 2003
    U.S.A.
    210
    Re: Offset question
    You can change your wheels and tires - even their sizes - just so long as it is done correctly,which typically requires a professional as well as a custom fitment. So 'one-application-fits-most' would definitely be a mistake, on this vehicle.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    .....It's really not all that complicated.
    You can use whatever diameter rim you want, as long as the outside diameter of the new tire is within ~1/4" of that of the OEM tire.
    Keep width and offset the same or VERY close, and there should be no rubbing issues.
    Look up the specs of your OEM tire size on www.tirerack.com . Then, look at tires of the same width, but 22" rim size, and figure out which aspect ratio you need to keep the OD the same as the OEM tires.
    What are you referring to by "staggered"? Width?
    joesboat is offline Cadillac Owners Member
    Automobile(s): XTS
    Apr 2013
    16
    Re: Offset question
    I'd try my best to keep the offset, rim size and rim weight as close as possible. The entire suspension on each corner of your car and each part is designed to work together. Those factors I just listed determine the bound/rebound and overall ride comfort.
    Of course I've always turned a blind eye to that stuff when it came to sports cars, drag racing. I actually wanted the stiffer ride and swapped everything out from shocks/springs/wheels/tires/swaybars etc... but if you're doing that in a wicked expensive Caddy; eh man I dunno to each their own but I wouldn't do a damn thing to mess with the smooth ride of the XTS.
  15. Remove Advertisements
