Music Stored on Flash Drive
Results 1 to 2 of 2
Cadillac XTS Forum Discussion, Music Stored on Flash Drive in Current Cadillac Vehicle Discussion; Since there is only one CD in the car, I copied multiple albums on to a flash drive using playlist ...
    Stoofpilot is offline Cadillac Owners Member
    Automobile(s): Platinum XTS
    Jul 2013
    Wilmington, NC
    31
    Since there is only one CD in the car, I copied multiple albums on to a flash drive using playlist from my iTunes. Funny this happen. None of the playlist names showed up in CUE but the album names showed up. Unfortunately, some songs from the same album were in different playlist so I got a bunch of duplicates and way too many album names.
    Question? Does anyone know how to get the system to reconize the playlist names.
    I found a work around that worked great. Went in to the folders on the flash drive. Did a shift select of all songs in folder then went to properties and changed album names to the playlist name of each folder.
    Put the flash drive back in the USB port and now all of the playlist names appear under the "Albums". Works great.
    CDN XTS is offline Cadillac Owners Fanatic
    Automobile(s): 1995 SLS -> 2003 STS ->2013 XTS Platinum ->2016 CT6 Platinum
    Dec 2012
    Oakville, Ontario, Canada
    203
    Re: Music Stored on Flash Drive
    I posted extensively about Music on Flash Drives/SD drives, playlists and artwork - search under my name both sites XTS and CUE - that should assist you with playlists.
