Results 1 to 14 of 14
Thread: Exit Setting
    Cadjiek is offline Cadillac Owners Fanatic
    Automobile(s): 2015 xts Premium fwd 2009 CTS AWD
    Apr 2009
    472
    Exit Setting
    Iam still experiencing a problem when opening the door to exit the car. The exit setting stops too soon. Am I getting out of the car too quick or what? Anybody else?
    RockvilleXTS's Avatar
    RockvilleXTS is offline Cadillac Owners Fanatic
    Automobile(s): XTS Platinum
    Dec 2012
    Rockville, MD
    153
    Re: Exit Setting
    I had that problem at the beginning, and to my embarrassment, discovered it was a user error. When I was opening the door, my hand was slightly touching the buttons for the memory seats, and I didn't realize it. That stops the full activation of the memory seat setting in its tracks. Check to see if you are doing the same thing. Avoid touching the memory buttons when you open the door.
    handymantoo is offline Cadillac Owners Member
    Automobile(s): 2013 Premium XTS
    Oct 2011
    64
    Re: Exit Setting
    I had this problem and the dealer replaced the seat module or reprogrammed it AFTER the CUE upgrade, and it now works fine.
  5. #4
    Apr 2009
    472
    Re: Exit Setting
    Mike
    I just got my car back yesterday. They performed the update you just described but it didn't help.
    Cadjiek
  6. #5
    cblove is offline Cadillac Owners Fanatic
    Automobile(s): 2014 BMW 535ix M Sport & 2010 Escalade
    Sep 2011
    103
    Re: Exit Setting
    Cadjiek, this may seem elementary but have you tried re-setting the exit setting?
  7. #6
    Apr 2009
    472
    Re: Exit Setting
    I think RockvilleXTS got the right answer. I watched my hand when opening the door, and I could see the side of my hand hittting the panel with the buttons. I guess when in a hurry that's what I was doing. I'll keep an eye on it. Thanks guys.
  8. #7
    Caddy Daddy.com's Avatar
    Caddy Daddy.com is offline Cadillac Owners Member
    Automobile(s): 2013 XTS Platinium 4WD 2003 EXT
    Dec 2012
    Napa California
    53
    Just had my CUE updated and this feature worked perfect before the update. Now seat will not go back with this feature on. Where is the check list that dealers should have to make sure all works. My dealer is one hour from my home. DADDY
  9. #8
    Apr 2009
    472
    Re: Exit Setting
    Daddy
    Did you try setting up your exit settings when you got home? I had to re do all the exit settings and seating settings when I got home. Another strange thing, I couldn't get the settings to register. For some reason the fob I was using before I took it in was being used as fob #1. After they did what ever to the control module the fob works as the #2. The #2 fob I had as my spare now works as #1. Weird!! Maybe that will help you from having to go back to the dealer.
    Cadjiek
  10. #9
    Dec 2012
    Napa California
    53
    Quote Originally Posted by Cadjiek
    Daddy
    Cadjiek
    You are correct. Needed to program my EZ exit. Did not need to do this when the car was new. Thank you DADDY
  11. #10
    tlanham is offline Cadillac Owners Member
    Dec 2008
    Hartland, Michigan
    6
    Re: Exit Setting
    If you had the new CUE update did they tell and demonstrate there is a new way the seat memory works and they are Key FOB dependent now? So after an update you have to reset all the seat memory settings for each Key FOB. You have to push and hold the SET and the position simultaneously like in so many of the older vehicles. You should also figure which KEY FOB you have because one fob is for position 1 and one fob is for position 2.
  12. #11
    Dec 2012
    Napa California
    53
    Quote Originally Posted by tlanham
    My dealer nothing. They are very out of the loop or to busy to read the Cadillac update. I will test that out. I Just set up my exit seat memory with button on the door. DADDY
  13. #12
    Apr 2009
    472
    Re: Exit Setting
    Ever since they replaced my defective battery, this issue has gone away. Bad batteries cause all kind of funny things to happen in these high tech cars.
  14. #13
    Stoofpilot is offline Cadillac Owners Member
    Automobile(s): Platinum XTS
    Jul 2013
    Wilmington, NC
    31
    Re: Exit Setting
    Bad battery? FOB battery?
    Choosing correct FOB. So, my wife has hers and I have mine. What do we do? She complains that her seat never goes to her position when she gets back in the car.
    1. Using her FOB, do I lock and unlock the door then reset her seat and EZ exit with her FOB in the car then get out and lock and unlock with hers?
    2. Do the same with mine?
  15. #14
    Apr 2009
    472
    Re: Exit Setting
    I had a feeling somebody would ask that question. It was the car battery that was replaced two weeks ago. Car needed to be jumped a couple of times. Bad cell.
    You have to program her FOB.
    It's all in the owners manual.
  • You may not post replies
