Previous STS owner just bought new XTS Platinum and have a quick question - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Cadillac XTS Forum Discussion, Previous STS owner just bought new XTS Platinum and have a quick question in Current Cadillac Vehicle Discussion; Just curious, why does Engleman say that he has the feature (just pull the handle). Could it be related to ...
  1. #16
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    1,925
    Just curious, why does Engleman say that he has the feature (just pull the handle). Could it be related to trim level?
  2. #17
    sredmyer is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2007
    8
    Re: Previous STS owner just bought new XTS Platinum and have a quick question
    Quote Originally Posted by carter's_sts View Post
    From what I have been able to find out, this feature is not available on any trim level. It may have worked that way in early build cars but it doesn't in any trim level on current builds.
    That said it seems certain that this could easily be added because it would only require a software change. This means the change could be be made with a simple update to CUE. Of course that doesn't mean they (Cadillac) will ever do it, just that it is much more likely than something that would require actual hardware changes like power folding mirrors.
    Steve
  3. #18
    kipsts is offline Cadillac Owners Fanatic
    Automobile(s): 2013XTS Platinum, prior: 92,95,97,00,02,and 2005 STS
    Aug 2011
    Las Vegas
    352
    Quote Originally Posted by sredmyer View Post
    Steve
    My XTS is one of the first Platinum (custom ordered) delivered and it did not/does not have the ability to open the doors merely by the proximity of the fob. I don't believe it was ever an option on the XTS.
    Perhaps he doesn't lock (or auto lock) his car when he leaves it?
  5. #19
    gohawks63's Avatar
    gohawks63 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 Black Diamond CTS-V Coupe
    Feb 2008
    53
    3,342
    Quote Originally Posted by pkadanec
    The answer is correct, on the XTS you must push the button (once for drivers door, twice for passenger door and again to lock). I also had this feature on both of my SRX's (pull handle for unlock). I actually like the fact that I do not have to open the door, reach in and push the unlock button. You could set it to unlock all doors with the handle pull, but I felt this was a security issue for my wife if she was alone (apparently so did GM).
    That's how my CTS coupe works. I walk up to the car and simply open the door. I have all the audible notifications turned off so I don't know if it unlocks as I get near or if it occurs once I touch the pad (the coupe doesn't have handles). If I were to guess it would be the latter. I have it set where it unlocks both front doors, but it can be set to unlock only the driver side.
    When I leave, I simply close the door and walk away and the doors lock by themselves. I never have to touch the fob for either function.
    I know that the coupe is a bit different since it has the Corvette style doors that are completely electronic. The locks are logic based as opposed to a mechanism. When locking/unlocking using the interior lock button you don't hear the mechanism physically locking/unlocking. All you hear is an electronic beep.
    Not sure how different it is in the XTS.
    I would be surprised if the XTS doesn't have the touch sensitive door handles that would unlock as soon as you grabbed them (provided the fob is on you). My previous car (2006 Acura RL had that.
  6. #20
    Aug 2011
    Las Vegas
    352
    Quote Originally Posted by gohawks63 View Post
    The XTS does not have touch sensitive door handles unless you consider pressing a button the handle 'touch sensitive'.
  7. #21
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    the xts door handles work very similarly to the cts coupe door handles except they actually have a door handle
    the cts coupe has a switch pad (like the corvettes)
    the xts has the button/switch
    it's pretty simple and basically the same as the STS and CTS passive locking system except it gives you extra control by using the button to be able to hit it twice to unlock the other door
    still no need to touch the remote transmitter (which is the main point of the whole system)
  8. #22
    ra0007 is offline Cadillac Owners Member
    Automobile(s): XTS
    Nov 2012
    25
    I think there was a previous post on this. At the time somebody said that their dealer said that the "button" system could not be changed. Hard to believe, huh? If anybody finds out differently, let us know.
  9. #23
    Aug 2011
    Las Vegas
    352
    {While it certainly seems like this is getting way too much thread time} The XTS is not the same as the STS since with the STS all you need to do to open the door is have the key fob in proximity and then pull on the handle, whereas for the XTS you both need to have the key fob in proximity AND press the button to open the door, then pull on the handle. Pulling on the handle without pressing the button will not open the door as it does with the STS.
  10. #24
    RicktheRealtor is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS Lux III
    Aug 2004
    Calgary, Alberta, Canada
    62
    338
    Quote Originally Posted by kipsts View Post
    Having the button allows for control of both the front door (one push) and the remaining other doors (two pushes). I don't think the proximity fob on the STS opened all the doors, and if it did, it may not have been desireable to have all four unlock at once. For me, I think the button system is preferable.
  11. #25
    JSenecal is offline Cadillac Owners Member
    Automobile(s): NONE
    May 2012
    25
    My problem with the button is that you have to know if the car is already unlocked or not. Otherwise you could be locking an already unlocked car. Not a problem when you get in the car and drive away, but if you're doing a lot of in and out to load or unload the car, combinded with automatic locking, this could be problematic.
    It's very annoying when my current car (Olds 98) locks just as your pulling the handle (add on alarm).
    I noticed in the owners manual that it is possible to disable auto locking in this situation. Auto locking is re-enabled when you start the car.
  12. #26
    Sep 2007
    Wilmington, NC
    13,986
    yeah kipsts, i meant more like the CTS coupe system where you still have to push a button to open the door
    and as Rick pointed out the button allows for more control
    and the main point of the passive system is to not have to touch the remote to unlock the doors
    i guess the designers thought something like "well if you have to reach out to the door to pull the handle what's the big deal with pushing the button there first? plus you can get another function out of it with a second push of the button to open all doors"
    i also agree this is probably taken up too much thread time but i guess it's better than arguing about religion or politics
  13. #27
    Jun 2009
    1,925
    I think there should be a law about how car doors open..........just kidding.
  14. #28
    ral1960 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS Perf-Plat, fr 11 STS, 04 DeV, 76 Eldo Con, 74 Fltwd
    Jan 2005
    NC
    436
    Quote Originally Posted by RicktheRealtor View Post
    Correct, you have to open either front door first to open a rear door. One thing I miss from my DeVille is the pop-up trunklid.
    My cousin's late husband lost his right thumb as a boy--guess he would have been SOL with an XTS.
    Actually, he became a surgeon; he had special instruments made for 4 finger use.
    The Fob thing is almost a little too convenient--I'm forgetting about keys sometimes, since I have a battery-powered, push-button house door lock (which is very nice to have). At work, we leave the key in the company pickup during the day, and today I almost walked away with the key in the ignition in the middle of town.
  15. Remove Advertisements
