HP Just curious
Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By gohawks63
  • 1 Post By SC2150
Cadillac XTS Forum Discussion, HP Just curious in Current Cadillac Vehicle Discussion; The XTS 3.6 V-6 is rated @304 HP while the same engine in the CTS is rated @ 318. Where ...
    flying fossil is offline Cadillac Owners Member
    Automobile(s): Kinda Red XTS Premium
    Oct 2012
    Irvine, CA
    76
    HP Just curious
    Where does the extra power come from?
    I think the XTS could use about 350 HP and mix very well in the Euro/Asian crowd of premium sedans.
    Has anyone done any performance mods?
    gohawks63's Avatar
    gohawks63 is offline Cadillac Owners Connoisseur
    Automobile(s): 2012 Black Diamond CTS-V Coupe
    Feb 2008
    53
    3,342
    Re: HP Just curious
    I believe the difference comes from the exhaust plumbing. Because the engine is mounted transversly in the XTS it isn't able to use the same freer flowing exhaust that the CTS has.
    Keep in mind that the CTS too was rated @ 304 hp before the 2012 model year.
    On second thought it looks like the increased HP in the CTS is related more to intake changes. Not sure then why the XTS doesn't benefit from the bump.
    The following was from Car & Driver:
    The revised direct-injection 3.6-liter V-6 now puts out 318 hp and 275 lb-ft of torque, thanks mostly to intake changes, including larger valves, revised ports, and a tweaked camshaft that keeps the intake valves open longer. (The same engine makes 323 hp in the updated 2012 Chevrolet Camaro.) Compared to last year’s 3.6-liter V-6, this year’s iteration is nearly 21 pounds lighter; 13 pounds were saved by integrating the heads and exhaust manifolds, 2 pounds from a lighter-weight front accessory-drive cover and new connecting rods, and 5.5 came out from using a plastic intake manifold in place of last year’s aluminum piece. The base 270-hp, 3.0-liter V-6 carries over unchanged, and can still be mated to both a six-speed automatic and six-speed manual. The manual is no longer available with the 3.6-liter, however.
    NormV likes this.
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    May also have to do with power delivery. When changing intakes and exhausts and creating a freer flow, it may raise hp but often needs higher revving to get there.
    Since its a bigger car, like a truck, it may be tuned for better torque. Or, having a better torque curve...
    CDN XTS is offline Cadillac Owners Fanatic
    Automobile(s): 1995 SLS -> 2003 STS ->2013 XTS Platinum ->2016 CT6 Platinum
    Dec 2012
    Oakville, Ontario, Canada
    203
    Re: HP Just curious
    When I had my 1995 SLS I also had the service manual. Looking at everything on the two available engines SLS "275 hp" and STS "300 hp but with a lower torque", the only difference were stronger valve springs in the 300 hp motor. Perhaps that the case here between the CTS and XTS where the XTS has a slightly lower HP but perhaps a slightly higher torque.
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,819
    Re: HP Just curious
    Engines are identical, but the shape and design of the air intake box and the exhaust are the power differences.
    Just like the LS3 in a vette VS the camaro. Vette has a straighter shot for the air intake VS the box and 90* turn the camaro makes.
    NormV likes this.
  8. Remove Advertisements
