XTS GEAR and FINAL DRIVE RATIOS
Results 1 to 7 of 7
Cadillac XTS Forum Discussion, XTS GEAR and FINAL DRIVE RATIOS in Current Cadillac Vehicle Discussion; I have done a search and found gear and final drive ratios for 2011 Cadillacs and apparently there are a ...
    330GT is offline Cadillac Owners Member
    Automobile(s): 1999 STS,2013 XTS-P, 2014 XTS-P
    Oct 2012
    Southern California
    54
    I have done a search and found gear and final drive ratios for 2011 Cadillacs and apparently there are a couple different types of transaxles but was not successful on the XTS. Does anyone know the ratios for the 6 speed box and the final drive ratio for the XTS? Is there a specific type/identification for the unit that I could search on the Net?
    Thank you for your input.
    BreakThrough's Avatar
    BreakThrough is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V Coupe White, 2014 XTSV-Sport Black
    Jan 2004
    Portland, Oregon
    187
    Re: XTS GEAR and FINAL DRIVE RATIOS
    I got this from GM's media site for the XTS.
    Transmission
    Type: Hydra-Matic 6T70 six-speed automatic
    Application: 3.6L V-6
    Gear ratios: (:1):
    First: 4.48
    Second: 2.87
    Third: 1.84
    Fourth 1.41
    Fifth: 1.00
    Sixth: 0.74
    Reverse: 2.88
    Final drive ratio: 2.77
    Oct 2012
    Southern California
    54
    Thank you very much for the info. I'll check that site.
    b4z
    b4z is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Standard SrX grey/black 2006 GTO
    Mar 2003
    Chas. SC
    54
    1,795
    Umm. I thought it was a 3.16 and the impala gets The 2.77. We need to get clarification on this.
    b4z
    Mar 2003
    Chas. SC
    54
    1,795
    Hmmmm. It is a 2.77. Looks like the gearing in the tranny should make up for it though.
    b4z
    Mar 2003
    Chas. SC
    54
    1,795
    I googled it and most of the dealers are quoting 3.16 and some of the GM info is 2.77.
    Oct 2012
    Southern California
    54
    Thanks. I did more "in-depth" searches also and I'm finding out that the 3.16 ratio is more common.
    For some reason or another the theoretical top end speed of the XTS, even with the 3.16 axle is over 200 mph - go figure. I'm just playing with math here, so let's not get all worked up with this.
    What I do know, is that mathematically in order to get to the often quoted 150+ a 4.25 axle or higher would be used. Then of course in real life, we have to deal with MANY variables (long list) to get to the real picture. It would be interesting if some road test mag. did actually do a full blown test on the XTS. I did calculate mathematically a 0-60 in 7.74 and I did read that some roadtesters did 0-60 in 6.9. Close.
    I know! I did not buy my XTS to go drag racing or do 150 mph - can't get above 75 around here and not get a ticket. It's just fun to exercise the little grey cells. If I want to go real fast, I have a couple cars in the garage designed just for that - but they're NOT comfortable at all - butt slappers.
  10. Remove Advertisements
