be careful of the auto venting feature on the XTS - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 37 of 37
Like Tree1Likes
Cadillac XTS Forum Discussion, be careful of the auto venting feature on the XTS in Current Cadillac Vehicle Discussion; Use the valet mode when you want to prevent the trunk from accidently opening. Never tried to see if valet ...
  1. #31
    handymantoo is offline Cadillac Owners Member
    Automobile(s): 2013 Premium XTS
    Oct 2011
    64
    Re: be careful of the auto venting feature on the XTS
    Use the valet mode when you want to prevent the trunk from accidently opening. Never tried to see if valet mode prevents venting.
  2. #32
    docjay is offline Cadillac Owners Member
    Aug 2012
    87
    Quote Originally Posted by Cadillac Tony View Post
    The dealer may not want to, but you can.
    Open the key fob by removing the key from its bottom edge and then gently prying it apart with a small flathead screwdriver (open from the side, bottom edge, working your way up).
    Once you get inside you'll find that the buttons work by way of a magnet pressing a circuit board. Put a sticker or two over the magnet you want to disable (trunk release or door unlock), then put the fob back together.
    Problem solved.
    Thank you - I had not thought of this and just tried it. I used heavy duty tape but it's not actually a magnet. So that did not work, but it did make it much less sensitive (have to push pretty hard to pop open the trunk) so hopefully it won't happen as often. Thank you again for the tip!
  3. #33
    330GT is offline Cadillac Owners Member
    Automobile(s): 1999 STS,2013 XTS-P, 2014 XTS-P
    Oct 2012
    Southern California
    54
    I solved my problem (for now) by buying a leather business card holder. It has two pockets and is 4x2.75x0.5 thick. The thickness is expandable to 0.5. The flap folds over and closes the leather case. I made sure that the closing cover did not have a magnet - one never knows how it would affect the remote. I haven't had any issues since, but the inconveniences are obvious if you need to press on a function. You have to pull the remote from the case. The other issue is that you have something extra to drag along with you. I must say that I can open the doors and trunk with the case in my pocket. When in the car, the case is in the center arm-rest box close to the pocket where the remote is normally inserted. So far, all seems to work. I'm now trying to find something smaller like 3" instead of 4" long.
    Hope that helps someone.
  5. #34
    CAPT Mike is offline Cadillac Owners Fanatic
    Automobile(s): 2013 XTS
    Sep 2012
    Boiling Springs PA
    70
    206
    Your answer is right on this forum; advertised as keywraps (keywraps.com). Look on the left side of the forum messages.
  6. #35
    Aug 2012
    87
    Quote Originally Posted by CAPT Mike View Post
    I have tried various key fob wraps and covers. They don't work for this problem.
  7. #36
    PC12's Avatar
    PC12 is offline Cadillac Owners Member
    Automobile(s): XTS4
    Jan 2013
    50
    8
    I came out tonight and truck was open and full of snow.
  8. #37
    meniisoc is offline Cadillac Owners Member
    Oct 2004
    26
    PC12, what a "delightful surprise" from the "standard of the world".
    Any pictures you want to share with us, or the marketing department of Cadiilac?
  9. Remove Advertisements
