Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: 06 v 6500 mile,s as new pan seals leak.
    Oct 2013
    9
    can anyone tell me why I have to pay 3500 dollars to have seals put on a car with 6500 miles its leaking up near filter@ front pan? Thank,s jerz
    rbzstsv is offline Cadillac Owners Fanatic
    Automobile(s): stsv
    Mar 2013
    491
    The oil pan gasket is leaking? Does your xlr get driven alot? I see you wrote it has minimal mileage.
    GizmoQ's Avatar
    GizmoQ is offline The Last Good Gremlin
    Automobile(s): 06 XLR-V and 96 Eldorado ESC-V -- One day ;)
    Mar 2007
    St Louis, MO
    2,653
    Re: 06 v 6500 mile,s as new pan seals leak.
    A car is designed to be driven. If not, seals and gaskets tend to dry out, rubber tends to dry rot, and belts will deteriorate.
    My car sat for two years before I got it. And within the first 500 miles, a belt let loose and pulled the front seal. As with your oil pan gasket, the whole front clip and radiator has to be removed and the suspension dropped to effect the repairs.
    Snake Bit Super Chilled Black Raven 2006 Cadillac XLR-V aka Elwood (Jake's brother)
    Verified 510RWHP and 546TQ so far...final goal 575/550
    ELWOOD - "Corvette in a Tuxedo ... with a Jet Pack"
    2013 St Louis Region SCCA Solo SSM Class Champion
    Texas Mile Record Holder: Street Legal XLR @ 165.6MPH
    ECTA LSR Record Holder: 4.2-5.0L Blown Gas Modified Sports Car
  5. #4
    Oct 2013
    9
    Thanks for reply on seals for what i paid knew Id have issue,s you confined my thinking great sight. jerz
  6. #5
    Jun 2012
    320
    Quote Originally Posted by GizmoQ
    A car is designed to be driven. If not, seals and gaskets tend to dry out, rubber tends to dry rot, and belts will deteriorate. My car sat for two years before I got it. And within the first 500 miles, a belt let loose and pulled the front seal. As with your oil pan gasket, the whole front clip and radiator has to be removed and the suspension dropped to effect the repairs.
    Though that seems odd with the latest advances with gasket composition...and a bit concerning since a lot of us (raises hand) parks their beloved XLR for the winter.
  7. #6
    Oct 2013
    9
    Gizmo thank you for all your info, still seeking a resolve on this issue of seals preciate your time jerz
  8. #7
    Jun 2012
    320
    Pm inbox full...:
    Quote Originally Posted by jerz
    Worked with this GM dealership for many years there honest and upfront, how much of my car we'll have to come apart to fix this inconvent leak? Is it true the whole front end must come off to address this problem 3600 dollars worth? The car is pristine knowing this I don't like the idea of my car being taken apart your thoughts? Jerz
    If the leak is minor with no oil stains below, I would opt for the correct synthetic oil and filter, put a few miles on it and see if it goes away. I have no real fears with the work to repair as long as you are clear about your concerns and the dealer has the certified XLR tech.
    Sometimes, a higher viscosity oil (running in a cold climate) and perhaps overfilling can cause a higher than normal oil pressure and a premature seal leak. The question is, will this reseat? This is usually why I drive conservatively ( keeping RPMs lower) until the car heats up. I am thinking it is rare for a seal to wear and leak with long periods of non-operation (thinking the old school seals, where this was a cause), which was why I was thinking the incorrect oil/cold weather scenario.
    If your dealer is really reputable, ask about the possibility of a "weeping" seal getting better with routine use. It would be interesting to see what they think.
  9. #8
    Onalaska's Avatar
    Onalaska is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS 1SF, 1990 Allante, 2006 XLR-V
    Oct 2006
    Coldspring, Texas
    65
    270
    Quote Originally Posted by jerz View Post
    Mine started leaking at about 45,000 miles. Front timing chain cover. Fortunately it was fixed under warranty. I just changed oil and noticed it leaking again now at 70,000 miles. No longer under warranty so I will just live with it. It's not so bad that I have to park it on the road yet to keep it from messing up the drive.
  10. #9
    Oct 2013
    9
    Thanks all for info let you all know resolve, on leak issues. Happy xlr to all. jerz...
  11. #10
    Oct 2013
    9
    Is this site still up and running? jerz
  12. #11
    GizmoQ's Avatar
    Mar 2007
    St Louis, MO
    2,653
    is this site still up and running? Jerz
    yeeesssss!
  13. #12
    Oct 2013
    9
    Finally figured it out there's not too much talk on X l R because there's not a lot of them which could be good or bad depending what side you're on! jerz
  14. #13
    Jun 2012
    320
    'Tis a shame. A recent club rally in Houston, where amongst cameros, mustangs, challengers, vetted, etc. I had the only one...Drew a lot of attention " what is this?"...wish Cadillac would bring back this car
  15. #14
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Guys feel free to post in the STS-V forum. Same LC3, MUCH more traffic.
  16. #15
    Oct 2013
    9
    Quote Originally Posted by Guy.Seminerio View Post
    Can anybody tell me where the build sheet and where to get the window sticker for my 06 xlr v thanks jerz
  • You may not post replies
