Elite Engineering Corvette C6, 1/4" Aluminum Tunnel Plate w/Thermal Abs
Results 1 to 1 of 1
Cadillac XLR-V Series Forum Discussion, Elite Engineering Corvette C6, 1/4" Aluminum Tunnel Plate w/Thermal Abs in Cadillac V-Series Forums; ...
    coati's Avatar
    coati is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Mar 2007
    The SF Bay Area
    185
    I just had installed today in my XLR-V, the Elite Engineering Corvette C6, 1/4" Aluminum Tunnel Plate w/Thermal Abs ($298 shipped).
    http://www.eliteengineeringusa.com/E...ent_Plate.html
    It is a direct replacement for the 1/8" thick OEM aluminum tunnel plate that comes with our XLR-V's and probably the XLR's as well.
    So far what I have noticed is a more solid & damped chassis that allows the suspension to work more effectively.
    The console temperature seems cooler, the cabin quieter and the ride and drive is more enjoyable.
    You may want to consider this if-
    •You want reduced interior and console temperatures
    •You want improved handling
    •Reduction of chassis flex (increases life span of expensive components which become adversely affected during high performance driving)
    •Less interior noise
    •Less interior heat
    •You want reduced creaks and squeaks
    Highly recommended!
  3. Remove Advertisements
