Oversize tires will work on the XLR-V!
Results 1 to 11 of 11
Cadillac XLR-V Series Forum Discussion, Oversize tires will work on the XLR-V! in Cadillac V-Series Forums; I decided to take the plunge and ditch the OEM Pirelli Euforia run flats for brand new non-run flat Michelin ...
    coati's Avatar
    coati is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Mar 2007
    The SF Bay Area
    185
    SmileOversize tires will work on the XLR-V!
    brand new non-run flat Michelin Pilot Super Sport tires on the XLR-V.
    Went with 245/40/19 front and 275/35/19 rear.
    It looks much nicer now with a wider, lower profile.
    So far so good with no clearance issues detected thus far.
    deadringer's Avatar
    deadringer is offline Cadillac Owners Fanatic
    Automobile(s): Modified 06 XLR-V
    Jul 2004
    Houston, TX
    164
    Re: Oversize tires will work on the XLR-V!
    Photos?
    Dr. Design is offline Banned
    Automobile(s): STS, XLR, STS V-Series, CTS V-Series, XTS....
    Aug 2003
    Design Center
    39
    3,406
    Hello,
    Very cool. Are you running this on the OEM rim? If so how do the side walls feel under load? I would be concerned about the aggressive plus size on those rims as they are only 8+" wide. The approved rim width is 9.0-10" for a 275 tire. Everything might be just fine, but I would want to make sure you were aware of that and make sure you take the time to put some real side load on that combo before you put a lot of trust in that combination.
    Thank you,
    Dr. Design
    D3 Cadillac
    Quote Originally Posted by coati View Post
    coati's Avatar
    Mar 2007
    The SF Bay Area
    185
    Quote Originally Posted by Dr. Design View Post
    Hello,
    Thank you,
    Dr. Design
    D3 Cadillac
    Thanks for your response and concern.
    Yes, I am using the OEM 19", 8 1/2" width rim.
    I'm aware of the recommended rim width of 9"+.
    I haven't pushed it that hard yet in the corners.
    They seem to be OK so far and the ride and grip is good, though initially the ride was a little hard.
    coati's Avatar
    Mar 2007
    The SF Bay Area
    185
    Photos!
    Aug 2003
    Design Center
    39
    3,406
    Looks good! Good job.
    Dr. Design
    D3 Cadillac
    coati's Avatar
    Mar 2007
    The SF Bay Area
    185
    Dr. Design
    D3 Cadillac
    Thanks Dr. Design!
    frmula505 is offline Cadillac Owners Member
    Automobile(s): 2006 XLR-v black
    Jan 2012
    56
    14
    I have a Black XLR-V also. What are the tire diameters of the two sized you used? If they are different, did it affect the ABS, Speedo, Or traction control?
    Thanks
    coati's Avatar
    Mar 2007
    The SF Bay Area
    185
    Quote Originally Posted by frmula505 View Post
    Thanks
    The front diameter is slightly larger than the rear just like OEM.
    Everything seems the same except the speedometer is slightly faster (1-2mph).
    GizmoQ's Avatar
    GizmoQ is offline The Last Good Gremlin
    Automobile(s): 06 XLR-V and 96 Eldorado ESC-V -- One day ;)
    Mar 2007
    St Louis, MO
    2,653
    I've run up to 285/35 rears with 255/40 fronts on my V and autocrossed it with no problem. But I run 18x8.5 on all 4 corners.
    Snake Bit Super Chilled Black Raven 2006 Cadillac XLR-V aka Elwood (Jake's brother)
    Verified 510RWHP and 546TQ so far...final goal 575/550
    ELWOOD - "Corvette in a Tuxedo ... with a Jet Pack"
    2013 St Louis Region SCCA Solo SSM Class Champion
    Texas Mile Record Holder: Street Legal XLR @ 165.6MPH
    ECTA LSR Record Holder: 4.2-5.0L Blown Gas Modified Sports Car
    Jan 2012
    56
    14
    I have 19x8.5 wheels for the front and 19x10 for the rear. Contemplating the size of tire I will go with. Would like a little more meat on the rears, due to the reverse lip on wheel (to keep the original offset). Thanks for your input.
  14. Remove Advertisements
