Page 3 of 3 FirstFirst 123
Results 31 to 44 of 44
Thread: Seeking Navi System!!!
  1. #31
    CadillacSTS42005's Avatar
    CadillacSTS42005 is offline Banned
    Automobile(s): 2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
    Oct 2005
    15,987
    Re: Seeking Navi System!!!
    ok
    right now i have nothing but a 97 etc with bose system
    tomarrow for 500 bucks im buying the denso dvd navi system with navi dvd and antenna
    (didnt wanna buy anything before i wasnt dead set on making it work or was at least 90% sure i could do it)
    heres the set up im buying
    http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
    before i buy it wanna know if the seville 98+ 6 disc changer used the same pin set up as my 97 eldorado 12 disc changer that way i know for sure i can connect my ipod to it (basically will the dvd player reccognise my 97 12 disc changer and be able to control it so when i install my ipod2car it will work and control my ipod, according to ipod2car it says all 96-04 eldo seville and deville uses the same adapter plug into the interface so i assume it will work)
    then it would also be nice to be able to have a rca (video and audio) in so i can connect a rear camera/nightvision or game system
  2. #32
    Oct 2005
    15,987
    dude i trust the forum plus theres nothin bad about ppl knowing ive posted it before heres my vin keep in mind navi never was an option for my car so idk what youll find
    1G6ET1293VU616146
  3. #33
    Sep 2006
    Poway CA
    49
    2,114
    I hope you did not buy iPod2car.
    12 disc will not be compatible with that Nav Radio, because that radio can see only 6 Disc.
    I can't pull any info on 97 for some reason it's not there.unless you tell me if 97 and 98 sevilles are the same.
    if not. this is the only option you have
    pretend this radio is aftermarket. I can have module done to power up this radio. then if you have aftermarket amps or some kind of amp, you can make your plugs, your voice guidance to work along with ipod XM 6 disc changer etc.. the only thing you will not be able to use is voice command, wich is not a big deal.steering wheel controls. posibility to duplicate, but not sure yet.
  4. #34
    Sep 2006
    Poway CA
    49
    2,114
    . looks like 97 eldo had an option for OnStar and GM was using class 2 data already, if this is the case. you options are not that bad, exept one thing that the radio that you are going to buy needs to be plear from old vin# before you install it
  5. #35
    Oct 2005
    15,987
    Quote Originally Posted by gm_geek View Post
    no i didnt buy an ipod2car yet why not is it bad?
    i dont even have the 12 disc changer anymore i sold it
    so your gonna make a module that plugs inline between the 32 pin and the plug that would give me the rca ins? did i read that right?
    97 eldos had the same system as a 98 eldo for some reason the online manual hates 97 but has all the info for a 98
    97 sevilles are completely different from 98 sevilles though
  6. #36
    Sep 2006
    Poway CA
    49
    2,114
    pretend you BCM will not accept this Nav Radio no metter what you do.
    so this module will generate data to power up Nav Radio that you are going to get. and then if you have aftermarket amps, I'll tell you how to repin your factory plug, etc. etc.
    the way that module works you can install this radio on the CIVC, or any other car.
    companys like PAC USA Spec peripheral and others use those modules to power up factory HU on their work bench.
    but we'll see. may be you'll not have to go that rout. I'll check some stuff tomorr
  7. #37
    Oct 2005
    15,987
    i really appreciate it man
    told you i wasnt a bb or cc lacky hahahaha
    im hoping and seems to reason
    my car accepted the 98 seville radio
    the write up and ppl have proven the navi will work on a 98 seville
    if a=b & b=c
    them a=c
    hopefully....
  8. #38
    Sep 2006
    Poway CA
    49
    2,114
    by the way. I did work at best buy. as tech support and also when installer did a major F**K UP, I had to fix it.
    my friends still make fun of me about it. but BB paid me so good for it, so i did not care if it was BB.
  9. #39
    Oct 2005
    15,987
    yuh as long as you know wat your doing bb has a good installer
    most a complete hack job artists though...
  10. #40
    Sep 2006
    Poway CA
    49
    2,114
    then after BB I went to work for GG. they offered me even more, but then those bustards went out of business
  11. #41
    Oct 2005
    15,987
    how much would that module cost me if i needed it made?
    just curious
  12. #42
    Sep 2006
    Poway CA
    49
    2,114
    that module is priceless. I'm gonna have to kiss some ass to get that module
  13. #43
    Sep 2006
    Poway CA
    49
    2,114
    let me know when you get your nav radio, and we go from there. do you have any aftermarket amps in your car ?
  14. #44
    Oct 2005
    15,987
    lol
    right now i have an amp for my speaks and an amp for subs
    if i get the navi im gonna go back and install the bose speaks and 4 mini amps for them and use and rca line adapter for the mean time for my subs
  • You may not post replies
