Bigger Tires For The Xlr
Results 1 to 10 of 10
Cadillac XLR Forum Discussion, Bigger Tires For The Xlr in Past Cadillac Vehicle Discussion; Am I alone thinking the tires on the XLR are too skimpy for the car? I am thinking about installing ...
    acfromla is offline Cadillac Owners Member
    Sep 2004
    27
    I am thinking about installing 255VR-40 on the existing wheels. Does anyone think this would be a problem with clearances and accuracy of the speedo.
    I also would not be opposed to changing the wheel size to 19".
    Just would like to know what might be a perfect after market tire/wheel combination to give it a better footprint or beefier looking stance. Still love the car and no problems after 12K miles.
    A wonderful machine.
    harryctsv is offline Banned
    Oct 2004
    851
    Re: Bigger Tires For The Xlr
    Quote Originally Posted by acfromla
    Hi acfromla,
    if you want to use your stock rims you have to get 255/45-18 tires and no speedo error will be there.
    I`ve just put the orinal V rims on mine with 235/45-19 on front and 255/40-19 on rear - no speedo error, better handling and smoother ride because I use the non-run-flat Pirelli`s.
    Harry
    RedGalant2k1's Avatar
    RedGalant2k1 is offline Cadillac Owners Connoisseur
    Automobile(s): N/A
    Apr 2006
    Michigan
    1,108
    why not just run what the corvette does?
    245/40-18s front.
    285/35-19s rear.
    That would even let you preserve using runflat tires.
    Oct 2004
    851
    Quote Originally Posted by RedGalant2k1
    245/40-18s front.
    285/35-19s rear.
    Hi RedGalant, I´m sure the front`s would fit but not the back ones!
    Hans
    Automobile(s): N/A
    Apr 2006
    Michigan
    1,108
    Quote Originally Posted by harryctsv
    Hans
    The XLR-V runs a 255/40-19 in the rear. The XLR as I'm sure you know rides on the corvette platform and physically the main underpinnings are the same. I wouldn't see why 285/35-19s couldn't fit in the rear.
    1_XLR's Avatar
    1_XLR is offline Cadillac Owners Member
    Automobile(s): 2006 XLR-V
    Corona, California
    18
    the wider tires will not fit the rear due to the oversized trunk limiting the inside clearance. the trunk being larger to accomodate the folding top.
    275 was the max I could get under my XLR.
    Sep 2004
    27
    Quote Originally Posted by 1_XLR
    I am curious to know what type of tire/wheel combination you were able to get for your XLR.
    I went shopping for wheels yesterday and wasn't very successful. Seems the XLR has a 50-55mm offset.
    I would appreciate any assistance..Thanks
    Sep 2004
    27
    Hi acfromla,
    Harry
    Harry,
    Where did you find XLR-V wheels for your car? I am having trouble finding aftermarket 19" wheel for my car. Seems the XLR has an uncommon offset.
    Appreciate any help...
    Anthony
    Oct 2004
    851
    Harry,
    Anthony
    Anthony, the stock XLR wheel and the XLR V wheel have both 61mm. I got my wheels from Bob (standby) on xlrforum.com because he put other wheels on his V.
    BTW Bob is from Aliso Viejo and I´ll be there on June 7th for the XLR-Rondezvous in ABQ/NM. We go there in his new Veeeeeeeeeeee
    Harry
    Automobile(s): N/A
    Apr 2006
    Michigan
    1,108
    Harry,
    Anthony
    MHT makes wheels that fit.
    MKW also makes wheels that fit.
  13. Remove Advertisements
