Any big problems with the XLR
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Cadillac XLR Forum Discussion, Any big problems with the XLR in Past Cadillac Vehicle Discussion; I was wondering if there has been any problems with the XLR?...
    vttrod Guest
    Kcryan is offline Cadillac Owners Fanatic
    Automobile(s): 1992 Tripple Black Allante, RIP 98 catera
    Mar 2004
    257
    Re: Any big problems with the XLR
    Alright ill get alot of yelling for this one..... but price....i just cant spend that much on an american car even if it is the best we can offer.
    Actually though i hear pretty good things about them, a few things here and there but good overall
    Jetboyphx's Avatar
    Jetboyphx is offline Cadillac Owners Member
    Automobile(s): 10 EXT, 76 Coupe DeVille, 73 Coupe DeVille
    Feb 2006
    Phoenix
    86
    There have been a few owners with top issues, seem to be earlier models. The batteries don't like to sit of extended periods is the most common gripe I have seen. Only problem I have had with mine is the push button did not release the drivers door one time, had to pull the emergency release. Only happened once and I don't know if I did something out so sequence or it was just a glitch.
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    Sep 2003
    DETROIT
    35
    22,381
    Faulty Delco batteries and/or parasitic discharging, a common problem on other Cadillacs too.
    Rear windows coming apart from their tops. Seems to only affect a handful of early models. I havent seen any posts on it since the the XLR hit the market a couple years ago.
    Some rattles in the dash. Dealers are instructed to install some new foam which takes care of it.
    I think by now, a lot of these issues have been worked out through production improvements or dealer repairs.
    Tuner@A&ACorvette is offline Cadillac Owners Member
    Dec 2005
    Valencia, Ca
    89
    all in all, good things are reported
    REALTORMG is offline Cadillac Owners Member
    Apr 2006
    ExclamationRe: Any big problems with the XLR
    driver side door just open when driving. 3times this happen. Top would not go back up. battery die after 30min in drive way. But I love the ride.
    Apr 2006
    drive side door would not open i had to used eme release. i put in shop and they said it was a shortest in the door open button.
    Jesda's Avatar
    Sep 2003
    DETROIT
    35
    22,381
    A few cases of leaking radiators and engine block seals (its a two-piece block). Rare, but for those affected its a pain in the butt. Actually, the oil leak isn't that uncommon.
    dbknight is offline Cadillac Owners Fanatic
    Automobile(s): 2006 SRX V8
    Aug 2004
    Columbia, MD
    41
    123
    My mother's is one year old (only 3k miles) -- has had no issues to speak of . . .
    dnelsch is offline Cadillac Owners Member
    Dec 2003
    I had problems with the top sensors early on (2004 model) - top would not retract. I had a computer fail once, which killed everything. I had a not-too-brilliant dealer service department put regular oil in instead of Mobil1 (same one that took a week to figure out computer problem was not a key fob!). I had a fuel transfer pump start to whine (and was replaced by a different dealer). Had a windshield stress crack - replaced by Insurance company - their cost almost $1600! Other than that great car! I love it!
    goslowornot is offline Cadillac Owners Member
    May 2006
    1
    biggest problem i've seen is with the onboard computer. trip mileage is sometimes completely unpredictable. when switching from primary driver to secondary driver it sometimes wipes out miles. other days it doesn't record miles at all. if you switch between personal trips and business trips it affects true mileage reports and you may not find anything at all! i've done this four times now to try to record a trip as business. they say this shouldn't occur but i have three different friends who have the same complaint!
    KvH
    KvH is offline Cadillac Owners Member
    Automobile(s): XLR, CTS
    Dec 2006
    Bahrain
    13
    i am experiencing some engine rumble on startup=engine light and the airbag light came on due to a loose wire under the driver seat.
    but right now the head engineer and me are following this up very closely and I' am treating the N* with some anti carbon stuff, WOT's and octane boosters ( fuel in Bahrain is not superiour quality, but hey, I pay 12 dollars to fill up my tank) and I think a black inside of the exhaust and smooth startups lately proove us right!
    I had one overheat situation once, and the guys installed a middle east spec radiator and cooling system for the car, even at 48C the car is ok now.
    The NAV and info-tainment system was also completely replaced with the more reliable 2006 version.
    Suicycle is offline Cadillac Owners Member
    Automobile(s): Just an XLR/V-series specialist GM technician at this point
    Oct 2006
    Kansas City, MO
    34
    21
    I just got done putting block half seals in an '06 with 3700 miles on it...not bad to do for me, but the owner was NOT happy...understandably so...
    IMHO, if GM would have put a Gen3 engine in it, the car would be perfect. The most problems I've seen have been front cover and oil pan leaks, radiator leaks, P/S resevoirs on the early '04's before the redesign...mostly powertrain related issues. As far as the top, the problems I've had are few and far between. I have ONE car here in the area that's had a TON of problems with the top, but the rest have been nearly problem-free.
    They're decent cars...I'm trying to find an '04 cheap at an auction so I can become an owner, and not just the one that has to fix them all
  16. #14
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    49
    11,051
    Folding top sensors
    Timing cover seals
    PS reserviors in early production
    Radiator
    That's the bulk of the warranty stuff I see and it's not really common.
    The most common are the top sensors, I can find those pretty quickly now but that wasn't always the case.
    The radiators are rare but not so rare if that make sense.
    A few campaigns in early production and lots of software updates for the PCM.
    They don't like Lo Jack if it's not hooked up just so.
    I do almost all the XLR work here and we have a lot of them that come in regularly for service. That is about all I have seen apart from some customers breaking stuff. We had one guy that left something in his trunk when he openend the top, it broke all kinds of stuff. Cost about $10,000 to fix. I could never prove he did it, but I could tell by looking at the parts what happened.
    The brakes can be squeaky, but there's not a lot you can do about it.
  17. #15
    Gearheaad43's Avatar
    Gearheaad43 is offline Cadillac Owners Enthusiast
    Automobile(s): 1997 Polo Green Cadillac Seville STS
    Nov 2006
    Georgia
    685
    Quote Originally Posted by Suicycle View Post
    Ummm How much on average are these XLR's running for at auctions?
  18. Remove Advertisements
