Intermittent no start 2005 XLR
Results 1 to 5 of 5
Cadillac XLR Forum Discussion, Intermittent no start 2005 XLR in Past Cadillac Vehicle Discussion; All the others tuff seems to work normally, it just won't start with the button sometimes. It is happening more ...
    Koooop's Avatar
    Koooop is offline Cadillac Owners Master
    Automobile(s): 300 SRT8, 392 cubic inches of tire smoking power!
    Jan 2005
    So Cal
    53
    8,189
    All the others tuff seems to work normally, it just won't start with the button sometimes. It is happening more often now.
    Any suggestions?
    ccclarke's Avatar
    ccclarke is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC CE, '04 CTS-V, '04 XLR, '13 XTS Platinum
    Apr 2004
    Uncanny Valley, New England
    1,678
    Re: Intermittent no start 2005 XLR
    Koop, it could be a lot of things, but first you have to isolate it to an ignition, interlock (transmission/brake), or Easy Key sub-system problem.
    It could be as simple as a bad ignition switch. It could be an intermittent switch that acknowledges when the brake is depressed during the ignition sequence. There are too many troubleshooting paths to try to write up a viable solution without more symptoms presented. Intermittent faults are some of the most difficult to troubleshoot.
    CC
    Koooop's Avatar
    Jan 2005
    So Cal
    53
    8,189
    I was hoping there was something easy the XLR has as a notorious trait on the issue. Actually, this is the only issue the car has ever had.
    Thanks for the reply.
    ccclarke's Avatar
    Apr 2004
    1,678
    Koop,
    I've read about this problem only once and it was isolated to a faulty ignition switch. They're relatively cheap and easy to replace. You can try re-seating the connector and/or cleaning the connector contacts. Also, you can remove the switch and cycle it a bunch of times with an ohmmeter attached to see how reliably it functions.
    CC
    Koooop's Avatar
    Jan 2005
    So Cal
    53
    8,189
    Thanks, I might just take a stab at it.
  8. Remove Advertisements
