2006 XLR Driver Door Issues
Results 1 to 6 of 6
Cadillac XLR Forum Discussion, 2006 XLR Driver Door Issues in Past Cadillac Vehicle Discussion; Hi guys, New member here, I posted an intro in the appropriate forum, but I have a question regarding my ...
    deodanth01 is offline Cadillac Owners Member
    Automobile(s): XLR
    Sep 2012
    5
    Hi guys,
    New member here, I posted an intro in the appropriate forum, but I have a question regarding my XLR.
    My car recently began to intermittently manifest a malfunction, which has become pretty much constant now. The car recognizes my Fob, and the passenger door opens fine, but the driver door will not open. I have to go through the passenger door and press the button to open the driver door. Occasionally, the inside button will stop working as well, and I have to use the lever. I have noticed that if I jiggle the driver door outside button, kind of an up/down thing with two fingers, it will occasionally release after a few tries. I figure that it may be the outside handle contacts or the like, however I have also noticed that I have to frequently re-index the driver door window as well.
    I know from reading the past posts that there are several contributors that are actual techs or experts, and was hoping that someone might have an easy fix for this problem, as my warranty period has lapsed and we all know how expensive these beauties are to diagnose and repair.
    Thanks!
    ~Rick
    XFireXLR's Avatar
    XFireXLR is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2008
    59
    3
    If you haven't already found a solution to your issue, it may just be your battery. Our cars doing weird things when the battery starts losing voltage.
    Automobile(s): XLR
    Sep 2012
    5
    Does anyone have the part number to the driver door handle? The rubber booted button deal, because I'm fairly sure it's the problem. Thanks!!
    hawkeye372 is offline Cadillac Owners Member
    Oct 2012
    9
    Quote Originally Posted by deodanth01
    Hi guys,
    Thanks!
    ~Rick
    Mine has just started doing this. I just replaced the batteries in both fobs hoping that might do the trick. Um. I will keep monitoring this and thanks for sharing. Ill keep the battery info in my mind. I guess the next issue is having the dealer do a battery check.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,687
    Re: 2006 XLR Driver Door Issues
    Any news, hawkeye372? If you decided to get anything checked into by a dealership, please be sure to keep us updated.
    Sarah (Assisting Katie), Cadillac Customer Service
    ccclarke's Avatar
    ccclarke is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC CE, '04 CTS-V, '04 XLR, '13 XTS Platinum
    Apr 2004
    Uncanny Valley, New England
    1,701
    The driver's door switch P/N is 751230. It's less than $10 at gmpartsdirect.com.
    CC
  9. Remove Advertisements
