Normal running Temperature on 2004 XLR running and at idle?
Results 1 to 8 of 8
Like Tree3Likes
  • 1 Post By ccclarke
  • 1 Post By GizmoQ
Cadillac XLR Forum Discussion, Normal running Temperature on 2004 XLR running and at idle? in Past Cadillac Vehicle Discussion; I just purchase 2004 XLR the Temperature on hwy seems to be like 190 to 200 but at a red ...
    Tommy50 is offline Cadillac Owners Member
    Automobile(s): 2008 CTS and 2004 XLR
    Apr 2012
    Mississippi
    55
    I just purchase 2004 XLR the Temperature on hwy seems to be like 190 to 200 but at a red light its pushing to 220 plus my question is what would be normal?
    ccclarke's Avatar
    ccclarke is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC CE, '04 CTS-V, '04 XLR, '13 XTS Platinum
    Apr 2004
    Uncanny Valley, New England
    1,666
    Re: Normal running Temperature on 2004 XLR running and at idle?
    The thermostat doesn't even open until 195 degrees to allow coolant to enter the radiator. The cooling fan low duty cycle starts at 204 degrees, and goes to high speed at 235 degrees. High coolant temp is 256 degrees at which time a message will flash on the DIC.
    While you're probably okay, when was the last time the DEXCOOL coolant was changed? If you don't know, it wouldn't hurt to do so.
    CC
    Eslic1 likes this.
    Apr 2012
    Mississippi
    55
    Not real sure but I will have it changed now thank you for your help
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,840
    Quote Originally Posted by ccclarke View Post
    The thermostat doesn't even open until 195 degrees to allow coolant to enter the radiator. The cooling fan low duty cycle starts at 204 degrees, and goes to high speed at 235 degrees. High coolant temp is 256 degrees at which time a message will flash on the DIC. While you're probably okay, when was the last time the DEXCOOL coolant was changed? If you don't know, it wouldn't hurt to do so.CC
    204 ??? or 224.
    The cooling fans cycle on and off with no A/C function set. Temp, in heavy stop&go traffic, should creep to about 224, fans go to SLOW, and the temp creeps down to 213, fans stop. Cycle repeats. With some A/C or DEFROST function set, fans run in SLOW all the time, so you should see temps of 195-205 all the time. I believe the fans don't even run over 40+ mph - they aren't needed. (Fans go to FAST at 304 - yep, 304 - degrees transmission fluid.)
    ccclarke's Avatar
    Apr 2004
    1,666
    The fan duty cycle switches to HIGH at 270 degrees for the transmission fluid. The cooling fan duty cycle starts when A/C pressure reaches approx. 160 psi and goes to HIGH speed at 360 psi.
    Regardless of vehicle speed, if the conditions warrant, the fan will run.
    Prefacing any submarine qual checkout with, "I believe . . . " always resulted in me getting lookups to make sure. Here's the hot cXXk: 2004 XLR Service Manual pg 6-595.
    CC
    GizmoQ's Avatar
    GizmoQ is offline The Last Good Gremlin
    Automobile(s): 06 XLR-V and 96 Eldorado ESC-V -- One day ;)
    Mar 2007
    St Louis, MO
    2,653
    Oh snap!
    Eslic1 likes this.
    Snake Bit Super Chilled Black Raven 2006 Cadillac XLR-V aka Elwood (Jake's brother)
    Verified 510RWHP and 546TQ so far...final goal 575/550
    ELWOOD - "Corvette in a Tuxedo ... with a Jet Pack"
    2013 St Louis Region SCCA Solo SSM Class Champion
    Texas Mile Record Holder: Street Legal XLR @ 165.6MPH
    ECTA LSR Record Holder: 4.2-5.0L Blown Gas Modified Sports Car
    RADARB8's Avatar
    RADARB8 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V TURBOCHARGED
    Feb 2009
    ELLICOTT CITY MD.
    69
    530
    Does the XLR-V radiator do a better job in coolant circulating and temps??? when swapped into an XLR ???
    And on my 99 vette i used to own the Dewitt radiator made a huge difference plus added the Devinces fan switch regulator so one can set when the main fan comes on...that was great...i never saw temps over 190 and i WAS sober...lol
    ccclarke's Avatar
    Apr 2004
    1,666
    The original (base) XLR radiator was prone to split. The design was improved when the V came out and subsequently installed in all XLRs during the build cycle. The only XLR radiator available from GM is the improved model. It's one of the cheaper (<$200 w/o labor) components to replace.
    My temp stays pretty much at 220 (it's 100+ degrees here) when it's really hot out. The car runs great. Idling at a light may induce the aux fan to start.
    CCC
    Eslic1 likes this.
  11. Remove Advertisements
