Anyone tried this for bluetooth?
Results 1 to 5 of 5
Cadillac XLR Forum Discussion, Anyone tried this for bluetooth? in Past Cadillac Vehicle Discussion; http://www.neocaraudio.com/products/BLUGM11 Says it takes the place of onstar and supports bluetooth calling and a2dp. Sounds perfect......
    pcm2a is offline Cadillac Owners Member
    Automobile(s): NONE
    Feb 2012
    8
    GizmoQ's Avatar
    GizmoQ is offline The Last Good Gremlin
    Automobile(s): 06 XLR-V and 96 Eldorado ESC-V -- One day ;)
    Mar 2007
    St Louis, MO
    2,653
    Re: Anyone tried this for bluetooth?
    Quote Originally Posted by pcm2a View Post
    A friend in Kentucky tried it and it kept draining the battery of his 08 XLR-V. I have it now and will start experimenting with it next month.
    Snake Bit Super Chilled Black Raven 2006 Cadillac XLR-V aka Elwood (Jake's brother)
    Verified 510RWHP and 546TQ so far...final goal 575/550
    ELWOOD - "Corvette in a Tuxedo ... with a Jet Pack"
    2013 St Louis Region SCCA Solo SSM Class Champion
    Texas Mile Record Holder: Street Legal XLR @ 165.6MPH
    ECTA LSR Record Holder: 4.2-5.0L Blown Gas Modified Sports Car
    Automobile(s): NONE
    Feb 2012
    8
    I'm mostly interested in steaming music and what I can control from the steering wheel and radio, like forward and back.
    I may end up subscribing to xm for a bit until I can find all that out.
    Phrede is offline Cadillac Owners Member
    Automobile(s): '08 XLR-V
    Oct 2009
    KY
    59
    3
    The CoStar unit does not support A2DP streaming. I am the one who kept having it hang on and drain the battery. 3 times. It was not reliable in other ways as well. I contacted Galaxy1000 and they say their unit will not work on XLRs. I'm currently going after using a Parrot unit.
    Bimota fan is offline Cadillac Owners Member
    Automobile(s): 2006 Black XLR-V
    Oct 2011
    56
    4
    The only negative I have heard about the Bluestar unit is it will drain the battery if something hangs up and it does not disconnect. Has anyone tried hooking up the unit to an ignition switched power source so that will disconnect when the car is turned off?
    Steve
  8. Remove Advertisements
