Service Stabilitrak TSB #06-02-35-002B
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By ccclarke
Cadillac XLR Forum Discussion, Service Stabilitrak TSB #06-02-35-002B in Past Cadillac Vehicle Discussion; ...
    jellyhead is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2008
    60
    I have been having an issue with the Service Stabilitrak message being displayed on the DIC. I found this TSB
    Code:
    2004 - 2008: Service Bulletin: Stabilitrak/Active Handling Light On,
    Service Stabilitrak/Active Handling Message on DIC
    Subject: Stabilitrak/Active Handling Light On, Service Stabilitrak/Active Handling Message on DIC, DTC C0710
    Steering Wheel Position Sensor (SWPS) Signal Set (Install Clip in SWPS Connector) #06-02-35-002B - (10/19/2007)
    Models:
    2004-2008 Cadillac XLR
    2005-2008 Chevrolet Corvette
    with Steering Wheel - Tilt, Telescoping (RPO N37 or N38)
    Condition
    Some customers may comment on a Stabilitrak® or Active Handling System light being illuminated. Also, this warning light
    will be accompanied by a SERVICE STABILITRAK or SERVICE ACTIVE HNDLG message on the DIC.
    Diagnosis with a scan tool may reveal a DTC C0710.
    Cause
    The most likely cause of a DTC C0710 on a vehicle equipped with telescoping/tilt steering wheel is high resistance in SWPS
    connector C202. Fretting terminal corrosion may be present in the SWPS connector due to the telescoping motion of the
    steering column. When the steering column is telescoped in and out, the female terminals within the SWPS connector may
    move on the male terminals of the SWPS. This movement between the terminals may cause a high resistance condition in
    the SWPS connector.
    Correction
    Remove the driver's side closeout (insulator) panel.
    Locate the SWPS connector that connects to the steering angle sensor, located on the lower center of the steering column.
    Install the clip (1), P/N 19179794, into the connector. This clip will act as a terminal positive assurance (TPA) and prevent
    any movement of the terminals.
    I checked for the DTC and there was nothing but with the car running I ran the steering column in and out a few times and noticed the message changed from Service Stabilitrak to Traction Control SYS Off.
    Has anyone performed this fix and is there a step by step guide?
    alarmu12 is offline Cadillac Owners Member
    Automobile(s): 2007 XLR & 1993 FLEETWOOD BROUGHAM
    Aug 2010
    HACIENDA HEIGHTS, CALIF. 91745
    81
    84
    Re: Service Stabilitrak TSB #06-02-35-002B
    I am having the same problem with my 07 XLR. It has been to the dealer 4 times and a few days later the traction control and the stabilitrack lights are back on again. When I restart the car it sometimes goes away and sometimes it does not go away. Sometimes the message goes away, but the car with the lock light stays lighted. Any help would be appreciated.
    Aug 2010
    81
    84
    Yesterday I drove the XLR and while I was driving it I put the steering wheel in and out and sure enough several dash lights came on and the trans locked in the 3rd gear emergency mode. Thanks for the advise that the dealer did not know about after 4 trips to it.
    Aug 2010
    81
    84
    I went in and had the above service done and I am still having problems. They are searching now with 3 more days in the shop and still counting.
    Aug 2010
    81
    84
    Got it back with the pcm replaced and reprogrammed. The lights are out for now.
    ccclarke's Avatar
    ccclarke is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC CE, '04 CTS-V, '04 XLR, '13 XTS Platinum
    Apr 2004
    Uncanny Valley, New England
    1,726
    Which module was replaced to restore StabiliTrac? (No PCM on the XLR.) Was it the EBCM (Electronic Brake Control Module?)
    CC
    gozzy3386 likes this.
    Aug 2010
    81
    84
    It says PCM shorted J6360 replaced and programmed PCM. Set electrical 423 WC4 , 1 19210736 ECM Cal state 874299.
    46653 shorted PCM. J6360 1.60 follow the diagnosis test and replace PCM, reprogram PCM, ck PCM connectors, perform crank position relearn, set electrical.
    Crestview Cadillac in West Covina, Calif. Has a good man Gordon Armstrong, who will not give up, no matter how long it takes to solve a problem. His knowledge is really deep on the Tach II.
  10. Remove Advertisements
