Hotchkis Sway bars (part #2284)
Results 1 to 6 of 6
Cadillac XLR Forum Discussion, Hotchkis Sway bars (part #2284) in Past Cadillac Vehicle Discussion; I just installed Hotchkis sway bars (part #2284) on my '04 XLR. The bars greatly improved the corning of the ...
    eric96816 is offline Cadillac Owners Member
    Dec 2005
    28
    I just installed Hotchkis sway bars (part #2284) on my '04 XLR. The bars greatly improved the corning of the car! In order to install the rear sway bar (XLR 4.6 does not have a rear sway bar) I purchased the following from GMpartsdirect.com :
    Link 20822934 2ea 20.57
    Clamp 25933429 2ea 5.61
    Bolt 11515775 2ea 2.64
    Nut 11516078 4ea 2.64
    Although specified for a Corvette C6, the sway bars were easy to install. The corvette shop charged me 3 hours ($200) to install the bars. I am glad I invested in the sway bars!
    deadringer's Avatar
    deadringer is offline Cadillac Owners Fanatic
    Automobile(s): Modified 06 XLR-V
    Jul 2004
    Houston, TX
    164
    Re: Hotchkis Sway bars (part #2284)
    You could have done them yourself and saved some money... it doesn't take 3 hours... maybe one.
    http://www.cadillacforums.com/forums...sway-bars.html
    But they do improve the rear swing out on corners... a lot.
    One side note... after about 8 months, the bushings on mine started squeaking... I haven't gotten around to lubing them yet, but just an FYI
    Which corvette shop did you use to install them?
    Dec 2005
    28
    Chuck's Corvette in Honolulu, Hawaii.
    alarmu is offline Cadillac Owners Member
    Automobile(s): XLR, ELDORADO & FLEETWOOD BROUGHAM
    Apr 2010
    HACIENDA HEIGHTS, CA.
    81
    27
    Is this sway bar really needed and noticeable if you are driving the car normally.
    ccclarke's Avatar
    ccclarke is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC CE, '04 CTS-V, '04 XLR, '13 XTS Platinum
    Apr 2004
    Uncanny Valley, New England
    1,667
    SmileRe: Hotchkis Sway bars (part #2284)
    I think the rear swaybar upgrade is a nice upgrade for the money. If you don't spend a lot of time driving the car hard, you probably won't miss it. For the occasions when I'm driving on curvaceous roads I like the way it keeps the car flat and allows me to push the car a little harder than I would have without it. I bought the C6 swaybar kit for less than $200 from gmpartsdirect and it took close to an hour to install myself, without ramps. Bolt-on perfomance mods are few for the XLR, and this one is a bargain. A torque wrench is the only special tool required.
    CC
    Dec 2005
    28
    As "CC" mentioned, there are not that many bolt-on upgrades for the XLR, which is one of the reasons I installed sway bars front and rear. The rear sway bar probably only engages and makes a difference when taking a turn at a much higher-than-posted speed limit, which I like to do on occasion. The rear sway bar increases my confidence when taking corners at higher than normal speeds. I also lowered the rear about 1 inch to match the front which I am sure helps on the turns - it also makes the car look sportier. I am glad I installed both sway bars even though I have few opportunies to take turns at high speeds since we have a limited amount of roadways here in Honolulu, Hawaii.
  9. Remove Advertisements
