Change light bulbs
Results 1 to 6 of 6
Cadillac XLR Forum Discussion, Change light bulbs in Past Cadillac Vehicle Discussion; How do I change the back-up and license plate bulbs. Is is a major challenge. Specific directions would be greatly ...
    Furlong is offline Cadillac Owners Member
    Automobile(s): Cadiallc XLR
    Feb 2010
    SmileChange light bulbs
    How do I change the back-up and license plate bulbs. Is is a major challenge. Specific directions would be greatly appreciated.
    Thanks
    ccclarke's Avatar
    ccclarke is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC CE, '04 CTS-V, '04 XLR, '13 XTS Platinum
    Apr 2004
    Uncanny Valley, New England
    1,711
    SmileRe: Change light bulbs
    Tools Needed: Trim Removal Tool
    Xtra retainers; these things are a PITA to get out and break easily. Luckily, they're cheap and plentiful at most dealers.
    Back-up Lamp Replacement:
    1) Raise the rear decklid.
    2) Remove the rear compartment inner rat fur trim panel (using the trim removal tool.)
    3) Disconnect the trim panel electrical connector.
    4) Disconnect the electrical connector from the back-up lamp assembly wiring harness inside the rear compartment decklid.
    5) Remove the (looks like 6) plastic wing nuts attaching the back-up lamp (bezel assembly) to the rear compartment.
    6) Remove the back-up lamp assembly (rear bezel) from the rear compartment lid.
    7) Remove the back-up lamp socket from the back-up lamp by depressing the locking tab and rotating the lamp CCW.
    License Lamp Bulb Replacement:
    8) Access the license lamp bulb/sockets (2) from the back of the rear compartment decklid.
    9) Rotate the bulb/socket CCW.
    10) Reverse the procedure to get it all back together. There are no torque specs.
    If you haven't done it yet, while you're back there, why not add one of the few mods GM made available for the XLR? There's a genuine rat fur monogrammed XLR rear tonneau trim panel available. P/N 19169562. It's $116.48 (MSRP is $160) from gmpartsdirect.com. It even comes with a complete set of extra trim fasteners! Here's a link with a pic (under accessories) http://www.cadillac.com/xlrPlatinum/gallery/
    Hope this helps you!
    CC
    Feb 2010
    Change light bulbs
    Thanks, work well.
    Like the mat and the screen behind the passenger/driver.
    alarmu is offline Cadillac Owners Member
    Automobile(s): XLR, ELDORADO & FLEETWOOD BROUGHAM
    Apr 2010
    HACIENDA HEIGHTS, CA.
    81
    27
    Thanks for the suggestion to change the trunk liner for the one with the cadillac emblem. I bought one and it is nice looking. One more little present for my baby. Bob
    ccclarke's Avatar
    Apr 2004
    1,711
    Do you mean the Rear Tonneau liner with the big, silver "XLR," wreath and crest on it? Definately a must-have and one of the few factory mods available for your XLR. And don't forget the Corsa exhaust!
    CCC
    Apr 2010
    81
    27
    Yes on the trunk liner and the exhaust system is on my radar.
    Bob
  9. Remove Advertisements
