Is there anyway to add Remote Start to an ('04) XLR?
Results 1 to 8 of 8
Cadillac XLR Forum Discussion, Is there anyway to add Remote Start to an ('04) XLR? in Past Cadillac Vehicle Discussion; I'd love to hear anyone's experience with remote start for the XLR. All the after-market people I've checked with seem ...
    Weston Anderson is offline Cadillac Owners Member
    Automobile(s): XLR
    Dec 2008
    1
    I'd love to hear anyone's experience with remote start for the XLR. All the after-market people I've checked with seem to think they can do it, but "upon further checking," they decide they can't. Thanks.
    ccclarke's Avatar
    ccclarke is online now Cadillac Owners Connoisseur
    Automobile(s): '02 ETC CE, '04 CTS-V, '04 XLR, '13 XTS Platinum
    Apr 2004
    Uncanny Valley, New England
    1,711
    Re: Is there anyway to add Remote Start to an ('04) XLR?
    I haven't heard of anyone employing an XLR remote start capability.
    Three things have to happen: 1) The vehicle needs to interrogate a fob in close proximity. 2) The vehicle needs to detect the brake is being depressed (not hard to do using a remotely-activated relay.) 3) The START button needs to be enabled (also easy, see #2.) The problem lies with the fob's method of communicating with the vehicle. The proximity requirement negates the remote requirement.
    All is not lost. I suppose you could leave a fob in the glovebox pocketslot and use a remote to enable the brake depressed and START switches, but that means you would have to disable the "fob in car" reminder, which I find useful, since getting locked out of this car is a real PITA. Here's some more fob 101 info:
    The XLR has several interior and exterior antennas to detect the presence of a fob. When the driver's door switch is pressed, the XLR transmits a DO NOT RESPOND signal to any fob located inside. This is called the SLEEP command. The SLEEP command temporarily commands any interior fobs not to respond to the door antennas. The SLEEP command is used in case someone is sitting in a locked vehicle with a valid fob, so that the the fob inside the vehicle doesn't allow a door to open from the outside handle switch. (Stalker disable.) When the SLEEP command terminates, the driver's door antenna activates so it will detect a fob on the exterior of the driver's door. If a valid fob is detected, the door is unlocked. When the START switch is depressed, the antennas are activated to detect the presence of a valid fob. If detected, the ignition sequence is permitted.
    I hope this is of some help to you.
    CCC
    Cliff8928 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS-V
    Jul 2008
    Long Grove, IL
    36
    416
    Speedbump is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2008
    6
    Yes there is
    deadringer's Avatar
    deadringer is offline Cadillac Owners Fanatic
    Automobile(s): Modified 06 XLR-V
    Jul 2004
    Houston, TX
    164
    Someone recently did it...
    Directechs is offline Cadillac Owners Member
    Automobile(s): NONE
    Mar 2010
    Vista, CA
    7
    Yes, this video is of a 2006 XLR successfully done at our facility last night using a Viper 5301 remote start and keyless entry system.
    deadringer's Avatar
    Jul 2004
    Houston, TX
    164
    Quote Originally Posted by Directechs View Post
    Any details on what modules were used? (I recently self-installed a 5901 in my '05 GMC Denali) Rumor had it that the Vette and XLR were cars to avoid in the past.
    Automobile(s): NONE
    Mar 2010
    Vista, CA
    7
    Quote Originally Posted by deadringer View Post
    It was installed using an 1101T module with a spare remote programmed to the car. The rumors WERE true, where these cars were not recommended because there wasn't a reliable way to mimic what happens when the car is started and stopped by a live person. Recent functionality changes in our systems and a resurrected interest in getting these cars done made the once impossible now possible.
    It certainly wasn't a car for the novice installer and is totally different than most cars out there as far as installing a remote starter goes, but it is certainly doable now.
    The spare remote is only powered up during remote start only, so the vehicle doesn't unlock unless the owner is nearby with the other remote. If some one breaks into the car, the car will shut down upon a door opening, or if the brake is pressed. If the unlock button is pressed on the Viper remote, then the owner can open the door and drive the car without having to shut it down and re-start.
  11. Remove Advertisements
