4.6 Northstar
Results 1 to 3 of 3
Cadillac XLR Forum Discussion, 4.6 Northstar in Past Cadillac Vehicle Discussion; Anyone out there have a good approx bone stock wheel hp for this motor? For the 2004 or 2005. Thx!...
    Davidstan's Avatar
    Davidstan is offline Cadillac Owners Fanatic
    Nov 2005
    Georgia
    403
    4.6 Northstar
    FrankT's Avatar
    FrankT is offline Cadillac Owners Enthusiast
    Automobile(s): 99 STS
    Mar 2004
    Michigan
    61
    700
    Re: 4.6 Northstar
    David,
    I am assuming you are referring to the Supercharged N*?
    Currently there are 4 N* power plants, LD8 fwd 4.6L~275HP, L37fwd~300HP, LH2 rear wheel dr~305HP, and the LC3 Supercharged.
    If you would like additional info on the supercharged N*, then go the the tech section, AJ posted a Tech link article that good info on the gm superchargers.
    http://216.182.211.32/techlink/image...7e.html#story1
    Naturally Aspirated, compression ratio~10.5:1, 300 HP, 4.6L displacement, 93mm bore x 84mm stroke.
    Supercharged, compression ratio ~9.0:1, 4.4L displacement, 91mm bore x 84mm stroke,~ 445 HP.
    Is the above at the rear wheels?, I'm not sure, I'll post again when I find out.
    Frank
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    Re: 4.6 Northstar
    Quote Originally Posted by FrankT View Post
    David,
    Frank
    LH2 is 320HP @6400RPM
