Alignment specs
Results 1 to 5 of 5
Cadillac V-Sport Performance Mods Discussion, Alignment specs in Cadillac CTS V-Sport; Does anyone have access to the stock alignment specs for the CTS Vsport Premium? I'd like to check alignment as ...
    hedrives's Avatar
    hedrives is offline Cadillac Owners Fanatic
    Automobile(s): 2014 CTS Vsport Black/Black
    Feb 2014
    Houston, TX
    158
    Alignment specs
    I'd like to check alignment as delivery alignment can be all over the place and I love tweaking mine a bit for handling.
    CapnCurt's Avatar
    CapnCurt is offline Cadillac Owners Fanatic
    Automobile(s): 2014 VSport 2014 SRX
    Feb 2010
    Fayettteville
    35
    107
    Re: Alignment specs
    I don't know but I did have to take mine back to the dealer beacause it was all jacked up.
    Glamisfan's Avatar
    Glamisfan is offline Cadillac Owners Fanatic
    Automobile(s): 2014 CTS VSport white tri coat/cashmere interior
    Oct 2014
    El Centro, Ca
    227
    Anyone have the specs or an alignment print out to share?
    Denrael's Avatar
    Denrael is offline Cadillac Owners Enthusiast
    Apr 2015
    SC Kansas
    671
    Re: Alignment specs
    So finally - here are the alignment specs for the CTS VSport (FE3 suspension), from the factory document:
    Front
    Camber: -0.5 deg +/- 0.8
    Cross Camber (L minus R): +/- 0.6 deg
    Caster: +6.3 deg +/- 0.6
    Cross Caster (L minus R): +/- 0.6 deg
    Total Toe: 0.2 deg +/- 0.2
    Steering Wheel angle: 0.0 deg +/- 3.5
    Rear
    Camber: -0.9 deg +/- 0.8
    Total Toe: 0.3 deg +/- 0.2
    Thrust angle (L minus R)/2: 0.0 deg +/- 0.3
    Some fairly liberal tolerance on camber at both ends... caster, not so much.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,306
    Re: Alignment specs
    Quote Originally Posted by Denrael View Post
    It always strike me as preposterous that OEMs will give specs that allow for positive camber. My Subaru is the same way.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  8. Remove Advertisements
