CUE Shutdown/Reboot - Page 4
Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 46 to 60 of 102
Like Tree10Likes
**Cadillac User Experience (CUE)** Discussion, CUE Shutdown/Reboot in Item Specific Cadillac Discussion; Originally Posted by georule Service called back this morning --Cadillac has instructed them to pull the plug on the original ...
  1. #46
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,687
    Re: CUE Shutdown/Reboot
    Quote Originally Posted by georule View Post
    Service called back this morning --Cadillac has instructed them to pull the plug on the original unit and install a new one, which will take another day to get. So I get another two days with the XTS (which is no hardship). This should make for an interesting test, to see if I have any more random reboots with the new unit.
    Hello georule,
    I appreciate you taking the time to update the thread. I apologize for the inconvenience you've been dealing with while having the dealer resolve your CUE system. Gregory and I will continue to look for additional updates. Don't hesitate to contact us if you would like to further discuss anything.
    Sincerely,
    Laura M.
    Cadillac Customer Care
  2. #47
    georule is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 SRX Luxury AWD Silver Coast Metallic
    Aug 2013
    53
    557
    Amanda from the Infotainment Team just called. She spoke with the dealer service people as well. She's of the opinion that probably my hardware was faulty, and it's just as well that the unit failed while the dealer was stressing it with an update, as that resulted in its early replacement. Better now than months of chasing intermittent problems that can't be replicated on demand by the service folks.
    She also said that the team would get my original unit back from the dealer and look it over for why it failed.
    So, hopefully this will be the end of it. . . . (we'll see!). We're planning another long driving trip (2,000+ miles) at the end of December, which will serve as a good test of whether the new unit exhibits the same behavior.
  3. #48
    pkadanec is offline Cadillac Owners Fanatic
    Automobile(s): 2013 XTS
    Mar 2009
    Gaffney, SC
    145
    I can tell you that the reboot issue is NOT defective hardware. I have had my head end unit replaced. This is a software bug.
  5. #49
    Mar 2010
    Detroit, USA
    12,687
    Hello georule,
    That’s great to hear that Amanda has been very active in your case. I am also glad that our team will be doing some additional research on your original unit. Thank you for keeping us all updated and please let us know how your trip in the end of December goes! We will be on the lookout for your future updates!
    Gregory W.
  6. #50
    Aug 2013
    53
    557
    Quote Originally Posted by pkadanec View Post
    It could be caused by both, of course. A random reboot is a sign of a catastrophic failure somewhere in the system --but the "where" isn't necessarily the same in all cases. I had five in less than three months.
    In my mind, entirely speculative but based on 30 years of working with computers, I keep coming back to heat buildup caused by intense multi-tasking over time. Like running the navigation and .mp3/.mp4/whatever decoding simultaneously for an extended period of time. There is variation in individual cpus and individual memory modules as to tolerance to heat --computer overclockers can go on about the subject at length. This would explain why it happens to some units and not others, and could lead eventually to total system failure (which my unit has now failed). It might also indicate a need to beef-up heatsinks or fans or radiators or whatever inside the unit.
    For instance, I used Nero to rip my CDs and let it do what it wanted --and it made .mp4 instead of .mp3. .mp4 is more cpu intensive to decode than .mp3. Did that play a role in my particular case? If it was heat-related, then maybe.
    But that's a seat of the pants analysis, and could be completely wrong, or only apply to a minority of cases. A memory leak/overflow (i.e. software) would also have cumulative build-up during an extended multi-tasking session resulting in catastrophic failure (random reboot), and would also fit the available facts (tho generally wouldn't result in eventual total system failure as happened to me).
    off1c3r likes this.
  7. #51
    Aug 2013
    53
    557
    Got my SRX back today (after a week and a new CUE unit).
    Tech notes say "Found DTC's u0029 and u0184 set in multiple modules"
    These are error codes that indicate in the first case "Vehicle Communication Bus A Performance" and in the second case "Lost Communication With Radio". I don't know that those are terribly helpful in providing them hints on where to look for the ultimate cause, but at least they would show it isn't all in the customer's head. . .
  8. #52
    Aug 2013
    53
    557
    So today was my first extended drive using navigation (while simultaneously playing music from a USB stick) with the new CUE unit that my local dealer installed last week.
    We were going to a restaurant about 40 mins away. We were within a few miles of it, when I turned a little too quick at a junction of several roads, and the nav should have recalculated the route. First it almost-not-quite-froze. Slowed way down (like I drove 1/4 mile on the new street and the nav updated from turn in 150 ft to turn in 120 ft). . . and then bang. . . screen went black, unit rebooted, blew away the USB music index entirely (it started playing one song from the lowest alphabetic named artist over and over again). It did resume the navigation automatically at least without having to re-enter the destination address once it completed rebooting.
    So, it wasn't the original unit having a one-off problem as far as my experience indicates.
    I'll send an email to Amanda at the Infotainment Team with this newest experience (#6 reboot in three months, #1 on this CUE unit). All happened while navigation and music decoding was happening simultaneously. . . and I *think* all happened when the nav was actually trying to "do something" like give verbal directions and/or recalculate the route.
  9. #53
    Aug 2013
    53
    557
    Heard back from Amanda at the Infotainment Team. They wanted to know if I was open to trying a different device that was 16GB or smaller (currently using a 32GB USB) and see if any difference was made. I ordered a 16GB SDHC Class 10 from Transcend to give that a try, since my music collection is about 9GB. They were more concerned about the size of the storage than interface type (USB vs SD). Switching USB to SD opens up another recharging option for me, so I thought I'd go that route.
    My impression is this is speculative and hunting around for data points on the team's part, rather than a definitive "do this and it'll work" kind of thing. But they likely have some reason to think it might make a difference.
    A good 16GB SDHC card only cost me $12.99 on Amazon, and is still big enough for my music collection (I understand that would not be true for everyone reading this), so I'm willing to play guinea pig on this one and see what happens.
  10. #54
    inspectorudy is offline Cadillac Owners Enthusiast
    Automobile(s): SRX
    Jul 2011
    697
    So the GM team can't buy a 16 GB card and try it themselves? Huh? They never tried this before talking to you?
  11. #55
    off1c3r is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ATS 2.0T Performance AWD
    Jun 2010
    NYC
    227
    I mentioned this on another thread, but using certain USB sticks in my 2011 CTS would at random cause the nav screen to freeze, all directions to stop, music to stop, and radio controls to stop working. Unless you turned off the car, there was no way to reboot the system. I had to wait it out until the head unit restarted and then it worked again. Problems went away after changing USB sticks. The USB stick in question was only 4GB. I tried two of the same model, both fresh formats in FAT32 and NTFS and I still had the issue until I changed it.
  12. #56
    Aug 2013
    53
    557
    Quote Originally Posted by off1c3r View Post
    Well, we'll see!
    The downside to SD is the interface itself is slower for folks with thousands of songs that need indexing. I'm middlin' at about 3,300 songs. Class 10 SDHC is 10 MB/s, but read speeds on better USB 2.0 memory sticks are 2+ that fast. But then the interface speed may not be the limiter in indexing speed anyway.
    Towards the end of next month I'll be taking a 2,000 mile driving trip with the nav+digital music going the whole way, so it'll be a good test. The last time I did that (tho it was over 3k miles that time), two weeks after I bought the car, it rebooted three times on the trip.
  13. #57
    Janeiowa is offline Cadillac Owners Member
    Automobile(s): SRX 2014. AWD
    Nov 2013
    22
    I have my SRX back after a week at the dealership. The new CUE didn't arrive when they'd expected it, so it was just yesterday that they called and said it was ready. So, the loaner Chevy went back and I got my car. I've not driven it a lot since yesterday, but so far, so good.
    I hope Cadillac has found whatever the problem is and resolved the issue of my CUE just going black at random.
  14. #58
    Mar 2010
    Detroit, USA
    12,687
    Quote Originally Posted by Janeiowa View Post
    Hello Janeiowa,
    I apologize that the CUE system didn’t arrive when they expected it would. I am glad to hear that they replaced your CUE system to address this concern. Have you experienced the concern further since you have had your vehicle back?
    Gregory W.
  15. #59
    Nov 2013
    22
    Gregory...I haven't driven it much...just around town and not at night, so I don't know if the top of the CUE changes to night mode and dims as I understand it's supposed to.
    Is it true, as I was told by a fellow 2014 SRX owner here in this little town, that GM/ Cadillac is doing a total redo/update/fix of the CUE software nationwide before Christmas? Has anyone else here heard this info?
  16. #60
    Mar 2010
    Detroit, USA
    12,687
    Hello Janeiowa,
    Please let me know if you do experience the concern again and keep us updated when you do drive it around at night. I have reached out to an internal resource of mine regarding a CUE update, but I haven’t gotten a response back as of yet. We are usually not made aware of updates or changes until the day they are rolled out.
    Gregory W.
  17. Remove Advertisements
