Go Back   Cadillac Owners Group > General Discussion > General Cadillac Discussion > Cadillac Tech Tips
Cadillac Tech Tips Submit your Cadillac related tech tips right here.
These tips will get added to the main site with a credit to the poster.
Cadillac Forums: How to check for a faulty FPR (Fuel Pressure Regulator) and replace it
  #46 (permalink)
Old 04-24-06, 11:52 PM
View acfcrown's Photo Album
Casino Cash: $250
Re: How to check for a faulty FPR (Fuel Pressure Regulator) and replace it
I Need Help!!!! My Problem Is Oppsite Of What Everyone Is Saying- My 96 Deville Sputters And Is Very Hard To Start When Cold - But Then Starts Easily All Day Long - Still The Fpr ?
  #47 (permalink)
Old 04-25-06, 10:16 PM
94CaddyConcours's Avatar
Cadillac(s): 1994 CADILLAC DEVILLE CONCOURS
View 94CaddyConcours's Photo Album
Casino Cash: $1180
OK i'm about to freak out. I dont have a vacum hose on my FPR. BTW its a 1994 De Ville Concours. And also to remove the for my car 93-94 the you need to remove 10 T30 bolts. It was a bitch to get the last two because it was not black but steel color. Somone point out what is going on. After I pulled the cover off there where sign of fuel all over the the place. ?????
  #48 (permalink)
Old 04-26-06, 10:49 AM
View Ranger's Photo Album
Casino Cash: $23801
The '93 & '94 Northstars had the fuel rail inside the manifold. As a result, it is subjected to manifold vacuum, thus no need for a vacuum line. Simply turn the ignition on to pressrize the fuel rail and look for fuel leaking from the FPR nipple. DO NOT CRANK THE ENGINE. If it starts in that configuration, it will run away unthrottled. If the FPR is leaking replace it.
  #49 (permalink)
Old 04-26-06, 02:05 PM
Casino Cash: $1180
OK thank goodness.
  #50 (permalink)
Old 04-27-06, 06:52 PM
Casino Cash: $1180
Well I turn on the ignition and no fuel leak. Also there is like I believe is fuel but it is dark as oil on the bottom inside my intake. Maybe its my Fuel Injector which I hope it isnt beace it would cost me 8 times more than a FPR.
Also there is a 2x4 black box connected to wire. What are they for? They look like there should be a hose connected to it.
Ranger should I put my cover back on and start it for and while and shut it down and take the cover off?
BTW the dealer discontinue the T30 bolts for the cover of 93-94
  #51 (permalink)
Old 04-27-06, 06:54 PM
Casino Cash: $250
Ranger Please I Still Can't Fix This - My 96 Deville Fpr Is Not Bad - I Tested It , It Was Fine Car Still Poor Starter But Runs Like A Watch Rest Of Day . Fuel Filter Maybe??? Im Desperate Nay Suggestions Will Be Appreciated Thanks
  #52 (permalink)
Old 04-28-06, 11:25 AM
Casino Cash: $23801
Remember, the PCV pulls crankcase gasses into the manifold and burns them. When you shut down, those gasses settle in the manifold. I suspect that is what you are seeing. Perfectly normal and it takes years to accumulate. Wipe it out and drive it for a few days. Then recheck it. I doubt you'll see any build up that soon.
  #53 (permalink)
Old 04-28-06, 11:27 AM
Casino Cash: $23801
Start with the basics. Get a fuel pressure guage on it and see what kind of fuel pressure you have, key on, engine off, then see what it is while cranking.
  #54 (permalink)
Old 04-28-06, 09:14 PM
Casino Cash: $1180
I still get horrible MPG, I suspect it the injector.
Is it advisable to use carb cleaner in the intake manifold. Also while I'm here, if I get a 95 intake Manifold would that increase my hp up to 300? Would it be possible.
Also how do I test the FI.
Also to correct my previous post: The dealer discontinue the 4 bolts that hold the intake, But the 10 pieces of T30 with rubber are not. They are sold as kit only. They run about $70 for all 10 bolts with rubber while I need only 2 bolts w no rubber. The previous owner use a stainless steel and it was pain in the arse to remove it.
I didnt get to look for the drain plug for the radiator yet can you also point it out?
  #55 (permalink)
Old 05-06-06, 07:24 AM
Casino Cash: $250
Ranger -you Wont't Beleive This My Deville 96 Runs Like A Top . The Problem Disappeared Starts Right Up Anytime I Guess It Was A Tank Of Bad Gas . As Soon As I Ran Real Low And Filled Up Again It Went Away.. Thanks For Your Help P.s. I Did Put In A Bottle Of Lucas Fuel Injection Cleaner When The Problem Started - This May Or May Not Have Helped But It's Good Stuff As I've Used It Before With Good Results
  #56 (permalink)
Old 05-12-06, 10:11 AM
Casino Cash: $250
So Much For All Is Well ! After A Full Tank Of Super She Was Running Like A Top - Heavy Rain Last Night - Now She Got Two Blocks , Stalled And Won't Restart - Sounds Like Not Getting Gas
I'm Guessing It's The Fuel Pump . Is Fuel Pump In Tank? Any Idea What This Will Cost Me ? Thanks Again
  #57 (permalink)
Old 05-12-06, 05:43 PM
Casino Cash: $23801
Yes, pump is in the tank.
  #58 (permalink)
Old 07-09-06, 11:55 PM
Casino Cash: $250
ranger can you help??? now ive got a new problem low oil pressure light and chime go off occassionally stop engine message comes on .. then goes away . im guessing bad op switch , right? by the way oil is full and car runs great + no noise at all
  #59 (permalink)
Old 07-10-06, 12:12 AM
Casino Cash: $23801
This section is for "Tech Tips". Please post questions in the proper section (Northstar).
  #60 (permalink)
Old 07-18-06, 11:27 AM
View eurumbaev's Photo Album
Casino Cash: $250
Great post. I seem to be having an opposite problem. My '94 Eldorado, 168k, has been having difficulty starting in the morning after sitting overnight, but once started, throughout the day starts on the dot. It seemed to be progressing worse and worse, untill today I wasn't able to start at all! Is it possible that a bad FPR might be causing this type of problem as well(even thought the symptom seem opposite), or would it be more likely the fuel pump? Any suggestions would be appreciated. Thanks!
Tags: , , , , , ,
check, faulty, fpr, fuel, pressure, regulator, replace
