Go Back   Cadillac Owners Group > General Discussion > General Cadillac Discussion > Cadillac Tech Tips
Cadillac Tech Tips Submit your Cadillac related tech tips right here.
These tips will get added to the main site with a credit to the poster.
Cadillac Forums: Cleaning your engine of evil carbon
  #16 (permalink)
Old 02-08-06, 02:57 PM
Sophisticated Member -V12-
Cadillac(s): 1996 Cadillac Fleetwood Brougham
View Cadillacboy's Photo Album
Casino Cash: $59041
Re: Cleaning your engine of evil carbon
I guess the story of cleaning carbon deposits are all wrong for the following instructions .What I know is that hit from 30 up to 80 MPH with the engine getting red line and then after hitting 80 MPH, let the car slown down to 20 MPH and then as soon as you get 20 , step on gas pedal till you see 80 on the speedometer .Repeat this 3 times in a month .....
Well, I also think that the very best way is to use a professioal lengine cleaner
  #17 (permalink)
Old 02-08-06, 03:07 PM
mtflight's Avatar
Cadillac(s): 2003 White Diamond DHS
View mtflight's Photo Album
Casino Cash: $4780
Top Engine Clearner: update
I performed the TEC carbon cleaning last night. With the engine idling, I sprayed it in the PCV hose... unplugging the vacuum hose made the car start to run rough.
I sprayed about 90% of the bottle in, and then thecar stalled when I plugged the hose back in.
Turned the car back on, and raised RPMs to ~2000 until the white smoke began to come out.
This morning I cranked her up, and raised RPMs to 2000 and so much white smoke kept coming out forever, and ever. I think I may have startled other neighbors--some lady got on her cell phone, or maybe she was already on it.
Easily a cloud the size of two 3 story buildings. Wow.
I then went for a brief drive to the dealership with a coupon for a $22 oil change. On my way I put it in 2nd and raised it near redline, then let the engine slow down. I did this twice--and no smoke or anything came out.
I got my oil change, then repeated the 2nd gear to redline, and engine braking down to 30 on my way in to the office.
Clean as a whistle.
The engine sounds crisper, more mechanical--top of the engine still has ticking sounds which are likely normal valve/cam sounds.
  #18 (permalink)
Old 03-16-06, 08:52 AM
Tailfin's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 1997 Cadillac Deville
View Tailfin's Photo Album
Casino Cash: $595
Hmm I keep thinking I have this stuff down, and then having second thoughts. I pour right into the TB, but basically going to the same place. How do you guys get so much smoke? lol... I poured it in until it was just about stalled, and then I finally got THICK white smoke for a bit...I turned it off then, poured a tiny bit more in, and started it up 20 minutes later. I got white smoke for a half minute or so, but it wasn't really really thick, or enough to create a huge haze or building-high cloud like I notice others seem to get.
Maybe my engine's too clean but I don't think so. I've done this with 2 cans of GM TEC and 3 of SeaFoam, and each time I still get more white smoke. Just wondering why I can't seem to get the "forever and ever" smoke...but I don't understand how one would get that anyway, because eventually the stuff's gotta burn off.
I noticed water mentioned too to steam clean it. I was just thinking of a happy medium here....would not be free, but dirt cheap compared to the cleaners... How about doing this with a load of plain isopropyl aclohol?
  #19 (permalink)
Old 03-16-06, 01:10 PM
mtflight's Avatar
Casino Cash: $4780
I think you're not referring to a Northstar. These instructions are specifically designed for the Northstar. Spray it in the PCV vacuum hose, car will begin to run a little rough... keep spraying until the can is gone.
AFTERWARDS, accel to 2000RPM until you see the smoke--then you turn off the car. I left mine overnight. In the morning, the cloud formed, again by accelerating to 2000 RPM.
  #20 (permalink)
Old 03-16-06, 04:26 PM
Tailfin's Avatar
Casino Cash: $595
Yeah I realize they were for N*...does it really build up THAT much more carbon than other engines though? It just seemed like it never got all of it out...as I can add another can and still get more smoke. I'm thinking I might try the isopropyl method...or at least do that after the water method...would ensure getting the water out.
  #21 (permalink)
Old 03-16-06, 06:39 PM
View Ranger's Photo Album
Casino Cash: $23801
I am not sure if the Northstar builds up more carbon or not. I believe it is more sensative to it though.
  #22 (permalink)
Old 03-16-06, 06:40 PM
View Beefmalone's Photo Album
Casino Cash: $250
Originally Posted by eldorado1
Please note the above is for 95+ northstars. The fluid should go to the middle nipple on top of the manifold. Don't pour it into the valve cover or something... Just follow the rear PCV hoses.
what about the older ones?
  #23 (permalink)
Old 03-17-06, 11:40 AM
mtflight's Avatar
Casino Cash: $4780
The smoke is not carbon. It is the solvents evaporating under the heat of the combustion chamber.
Leaving the solvent/vapors inside overnight is what insures that you dissolve the most carbon.
I think the situation with the Northstar, is that it was designed to be a high performance engine, and it is mostly underutilized in that role. So either it is more sensitive to the carbon or it builds more due to it's underuse.
  #24 (permalink)
Old 03-17-06, 01:59 PM
Tailfin's Avatar
Casino Cash: $595
Hmm, then is there any way to tell if you've got most of the carbon out? Don't say take off the heads
  #25 (permalink)
Old 03-17-06, 07:31 PM
mtflight's Avatar
Casino Cash: $4780
I'd say that if you did it properly, that should give you the peace of mind.
I think there is a way to look inside the engine with a borescope through the spark plug port. Don't ask for details, I haven't done it.
  #26 (permalink)
Old 03-17-06, 10:38 PM
Casino Cash: $23801
Yes, you can . I have one and have done it but you'll only see the top of the piston, not the underside of the head.
  #27 (permalink)
Old 03-19-06, 04:45 PM
FredMaxwell's Avatar
View FredMaxwell's Photo Album
Casino Cash: $250
Can I ask,
How come seafoam costs $5 a can if it's mostly rubbing Alcohol?
Good lord, for 92 cents you can get a bottle of 91% Iso
I buy the 50 cent bottles of 50% because it is a great way to wash your hands
Also, I always thought Alcohol would dry out your cylinder walls and rings.. what is the story?
PS: That TEC sounds like some good shit.. where do you get it?
Is that what they use in injector cleaning machines?
Or is it that can you run your engine off of to clean the injectors?
  #28 (permalink)
Old 03-19-06, 06:43 PM
Tailfin's Avatar
Casino Cash: $595
I also had to ask where to get it...at a reasonable price anyway. Just go to the nearest place you'd take your car that's an official GM Dealer, ask their parts section. Only about 7 bucks.
I was wondering about the isopropyl too. I also wonder if you can put GM TEC in the fuel in order to give the injectors a good blast...but I ain't gonna try it unless I'm reassured it's fine. Not sure what those chemicals would do to the pressure regulator and such.
  #29 (permalink)
Old 03-19-06, 07:38 PM
Cadillac(s): 1997 Eldorado
View Zorb750's Photo Album
Casino Cash: $1180
Probably wouldn't hurt it if you did it once in a while. I'm going to look into it myself and get back to you about that one.
  #30 (permalink)
Old 03-26-06, 01:12 AM
View AnotherToothpick's Photo Album
Casino Cash: $250
Where would I find the PCV tubes in a 4.9 engine (taking into account that I still have very limited knowledge of where everything is and what it's called)?
Also, does this process more or less have the same effect as adding carb cleaner to the TB tubes? I poured half a can of CC into the TB tubes while rodding them out, then let it sit in the engine overnight before starting it the next day and burning it all off... Unfortunately this did not solve my rough idle (800-1000rpm) or my sporadic knocking. Though I gather the rough idle could simply be the result of me needing a new O-ring throttle body gasket.
Tags: , , ,
carbon, cleaning, engine, evil
