Results 1 to 9 of 9
Thread: Difference in "scan" tool and Tech 1 or 2
    nphoenix is offline Cadillac Owners Member
    Automobile(s): 2004 deville
    Nov 2004
    36
    Angry Difference in "scan" tool and Tech 1 or 2
    I have an older AutoXray, and recently "loaned" a newer AutoXray from Autozone for free. It lets you scan for error codes and clear engine codes but cant access functions like getting into program mode for key FOB's. What products are full featured, preferably PC based to support full access? I saw a Tech 2 for $3700 on EBAY obviously I want a solution for much less. My 04 deville manual is full of steps that require more than scanning for codes with no alternate access.
    Mar 2005
    83
    Re: Difference in "scan" tool and Tech 1 or 2
    Did you ever find your answer?..I am looking for the same thing.
    Thanks
    Jan 2003
    Newtown, PA
    58
    6,472
    The greatest plus for the Tech 1 & 2 would be that they are supported by GM Techlink software. The problem is access to that software. If you aren't a dealer or supported entity, you can't get the software. Then you're stuck with general software that's pretty much the same as anybody else's scanner has. The hot ticket would be to get a Tech 2 and then find a dealer or supported shop that can get you the software.
  5. #4
    Nov 2004
    36
    I thought it was all mandated to be publicly available data. i just got off the phone with AutoXray and they refered me to the dealer for any non "powertrain" engine diagnostics. The scan tools can only read/ clear or monitor some points.
  6. #5
    Nov 2004
    36
    I think this is the tool i need - dont know if anyone rents one. http://www.vetronix.com/diagnostics/tech2/
  7. #6
    Mar 2005
    83
    Yea, Have you seen the price on that thing? No way I would buy it for the little I would use it...
    If you find a place to rent it...let me know.
  8. #7
    Logandiagnostic's Avatar
    Logandiagnostic is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS, 2005 Mustang GT, 2010 MINI S
    Feb 2003
    Franklin, TN
    1,118
    Yeap.......the aftermarket scanners only cover powertrain diagnostics.
    If you look at any GM service manual....the diagnostics have you plug in a GM Tech 2 for just about any issue.
    If you work on GM.....you must have a Tech 2.
    The Tech 2 does use a memory card that can be updated by simply plugging into another Tech 2 that has been updated. 4-5 minute procedure.
    The Cadillacs DO offer self diagnostics via the cluster. You may want to look into that angle.
    GM Tech 2....this one is ours....
    Logan Diagnostic
    www.ledfix.com
    www.airbagcrash.com
    www.crashdatainfo.com
  9. #8
    Mar 2005
    83
    I decided to buy www.autotap.com. I know it is not tech2, but it will have to do for me. I saw Bruce Bonebrake use this on Weekend Mechanic and it looked really cool and gave lots of information...(with the added modules). I also downloaded the demo and like the way it looks....I should recieve it this week and plan on using it right away. I will try to post here my findings.
  10. #9
    tedcmiller is offline Cadillac Owners Connoisseur
    Apr 2004
    1,827
    Beginning in 2004, Cadillac no longer provides diagnostic code readout through the instrument panel - you have to have an aftermarket code reader. As indicated in other posts to this thread, most of the inexpensive (< $500) aftermarket tools do not provide the capability of reprogramming or otherwise altering the computer settings.
  • You may not post replies
