Go Back   Cadillac Owners Group > General Discussion > General Cadillac Discussion > Cadillac Tech Tips
Cadillac Tech Tips Submit your Cadillac related tech tips right here.
These tips will get added to the main site with a credit to the poster.
Cadillac Forums: Motor Mount (Front) Replcaement
Old 05-27-09, 12:13 PM
View Ranger's Photo Album
Casino Cash: $24216
Courtesy of ejguillot
I've done the motor mount twice on the 2000 Seville, and if the Deville has a similar engine cradle (I think it does), here's how it will go (don't have pics handy):
1) get the front end of the car in the air, I used a pair of jack stands with a 12" piece of 2x4 on the top (to spread the load) on the body behind the cradle. Use your judgment as to where to put these.
2) put a 4" piece of 2x4 on your hydraulic jack, then put in under the engine in the oil pan area (My Northstar had a steel crossbrace piece going between the engine and trans, which proved ideal. You should have this too.) You will need this to support the weight of the engine, and lift the engine off the cradle (you'll need to do this to get the mount out). Pump up the jack until it just makes contact with the brace.
3) the mount has 2 studs coming out of it - 1 to the cradle (you can take this nut off at this point, it's a deep socket), and 1 to a supporting brace that attaches to the engine at 4 points (the brace will have to be unbolted from the engine, and comes out with the mount). Remove the brace to engine bolts at this point, gravity will keep the powertrain in place.
4) there are 6 bolts that attach the cradle to the frame (2 up front, 4 in back). the rear 4 are loosened, the front 2 will be removed altogether. Now, pump up the jack to support the weight of the engine, and remove the front 2 bolts, then loosen (about 5 turns from the point of removal) the middle 2 bolts, and loosen the rear 2 halfway. The brace and mount should separate away from the engine and be resting on the cradle.
5) To get the mount and brace out, raise the engine further with the jack, and you may have to pull down on the cradle to get the necessary clearance. Once the mount is out, unbolt it from the brace and install the new one (tighten this down properly, once installed you can't get to this bolt!)
6) Installation is roughly the reverse of removal, with the following things to look out for:
a: get the new brace/mount roughly in place, and bolt it to the engine. Torque to spec.
b: tighten the 4 rear cradle bolts, it'll close the gap for the front 2 bolts. Then (you will really want a helper at this point, but i managed to do it alone) push up the front of the cradle (if alone, have a piece of 2x4 or another hydraulic jack handy) enough to get the 2 front bolts started in their holes. Once started, torque all 6 cradle bolts to spec.
c: lower the powertrain down onto the cradle, and install the mount to cradle nut, torquing to spec.
you're done! Get the car down on the ground, and give yourself a pat on the back (and a beer too!) for doing what i consider a fairly advanced repair for the do it yourself owner.
  #2 (permalink)
Old 06-02-09, 09:18 PM
Casino Cash: $24216
Re: Motor Mount (Front) Replcaement
Tateos
2000 DTS is that same as above - that was exactly like I did it on my 2000 DTS
  #3 (permalink)
Old 06-03-09, 10:59 AM
CadillacSTS2003's Avatar
Zeeee-yaaaa
Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC
View CadillacSTS2003's Photo Album
Casino Cash: $12230
Same on STS
did it twice on moms 98
  #4 (permalink)
Old 06-04-09, 04:05 PM
ezed1's Avatar
Cadillac(s): 77seville (traded)82Eldog(died) 92sls-99sls(Traded)03deville
View ezed1's Photo Album
Casino Cash: $2645
Thumbs up Re: Motor Mount (Front) Replcaement
Yeap did the same thing to minds too oil pressure switch and those annoying crank sensors all in one shotwith the cradle down made it a hole lot easier to do!!!!!!!
front, motor, mount, replcaement
