Go Back   Cadillac Owners Group > General Discussion > General Cadillac Discussion > Cadillac Tech Tips
Cadillac Tech Tips Submit your Cadillac related tech tips right here.
These tips will get added to the main site with a credit to the poster.
Cadillac Forums: Northstar Crankshaft Position (CKP) Sensor replacement
Old 08-29-07, 07:31 AM
Cadillac(s): Member of Air Fuel Tuning (Cadillac Division)
View AJxtcman's Photo Album
Casino Cash: $13342
Crankshaft Position Sensor Replacement 2000 to 2005
Removal Procedure
Caution: To avoid any vehicle damage, serious personal injury or death when major components are removed from the vehicle and the vehicle is supported by a hoist, support the vehicle with jack stands at the opposite end from which the components are being removed and strap the vehicle to the hoist.
  1. Raise and support the vehicle.
  2. Remove the crankshaft sensor electrical connector. For specific CKP sensor identification, refer to CKP, EOL, EOP comploc - 2000 K .
  3. Remove the crankshaft retaining bolt.
  4. Remove the crankshaft sensor.
Installation Procedure
Important: Inspect the crankshaft sensor o-ring for wear or damage. If a problem is found, replace the o-ring.
Lubricate the crankshaft sensor o-ring with clean engine oil.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Important: Be sure to fully seat the CKP sensor into the engine block. Failure to fully seat the CKP sensor may cause a CKP sensor DTC to set.
Install the crankshaft sensor and the retaining bolt.
Tighten
Tighten the retaining bolt between 8-11N·m (70-100 lb in).
  1. Install the crankshaft sensor electrical connector.
  2. Caution: To avoid any vehicle damage, serious personal injury or death when major components are removed from the vehicle and the vehicle is supported by a hoist, support the vehicle with jack stands at the opposite end from which the components are being removed and strap the vehicle to the hoist.
  3. Lower the vehicle.
  4. Operate the engine and inspect crankshaft sensor for engine oil leaks.
  5. Perform the CKP System Variation Learn Procedure .
  #2 (permalink)
Old 08-29-07, 07:50 AM
Casino Cash: $13342
Re: Northstar Crank Sensor replacement
That is the way GM says to do it. Now this is my way.
Raise the car on the hoist
Remove the Front Air Deflector
Remove the bolt retaining the brake line bracket to the front of the cradle
Remove the front engine mount lower bolt.
Remove both of the front cradle bolts.
Un-clip the harness from the oil filter housing
Reach up to and un-clip the reddish connector locks on each connector. I use a hook shaped pick tool.
Un-clip both connectors from the crank sensors and move them to the side.
Use a 1/4 drive 10mm flex socket and a long extension and remove the retaining bolts.
Pull out both sensors.
Slide in the new crank sensors.
Bolt them in place
Reconnect the connectors and install the locks.
Re-clip the harness in place
Reinstall the cradle bolts and the motor mount nut.
Reinstall the brake line retainer bolt
Reinstall the front air deflector
Allow the engine to warm up to operating temp.
Relearn Crank Variance
  #3 (permalink)
Old 08-29-07, 07:53 AM
Casino Cash: $13342
If you do not have a hoist and you are using ramps and if you have small arms you may be able to reach up and un-clip the sensors, But I would say to take it to the dealer because you need to have the Crank Variance relearned any way
  #4 (permalink)
Old 08-29-07, 07:56 AM
Casino Cash: $13342
Crankshaft Position System Variation Learn
Caution: Before performing the Crankshaft Position System Variation Learning Procedure always set the vehicle parking brake and block the drive wheels in order to prevent personal injury. Release the throttle immediately when the engine starts to decelerate in order to eliminate over revving the engine. Once the learn procedure is completed, the control module will return engine control to the operator and the engine will respond to the throttle position.
  1. Set the parking brake.
  2. Block the drive wheels.
  3. Ensure the hood is closed.
  4. With the scan tool, monitor for DTCs. If a DTC is set, refer to Diagnostic Trouble Code (DTC) List/Type before proceeding.
  5. Start the engine and allow engine coolant temperature to reach at least 70°C (158°F).
  6. Turn OFF the ignition.
  7. Select and enable the crankshaft position variation learn procedure with the scan tool.
  8. Start the vehicle.
  9. Apply and hold the service brake pedal firmly.
  10. Ensure the transaxle is in park.
  11. Increase accelerator pedal position until the fuel cutoff is reached at 5150 RPM. Immediately release the accelerator pedal after fuel cutoff is reached.
  12. The crankshaft position system variation compensating values are learned when the RPM decreases back to idle. If the procedure terminates.
  13. Observe DTC status for DTC P1336.
  14. If the scan tool indicates that DTC P1336 ran and passed, the crankshaft position system variation learn procedure is complete. If the scan tool indicates DTC P1336 failed or not ran, check for other DTCs. If no DTCs other than P1336 are set, repeat the crankshaft position system variation learn procedure as necessary.
  #5 (permalink)
Old 08-29-07, 07:59 AM
Casino Cash: $13342
FIGURE CKP B, CKP A, Engine Oil Pressure Switch, and Engine Oil Level Switch(c)
Attachment 34821
(1) CKP Sensor B
(2) CKP Sensor A
(3) Engine Oil Pressure Switch
(4) Engine Oil Level Switch
  #6 (permalink)
Old 08-29-07, 08:51 AM
submariner409's Avatar
Casino Cash: $20264
AJ......What would happen if you replaced the sensors but did not perform the variance relearn ???
  #7 (permalink)
Old 10-12-07, 12:22 PM
FrankT's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 99 STS
View FrankT's Photo Album
Casino Cash: $7629
Bolt them in place
Thanks AJxtcman,
I followed your proceedure on an 01 Deville last night worked like charm
It took me less than 1/2hr.
Frank
  #8 (permalink)
Old 10-13-07, 12:20 PM
Domino1968's Avatar
Cadillac(s): 2000 Deville DTS
View Domino1968's Photo Album
Casino Cash: $970
I would like to know the answer to that question as well.
  #9 (permalink)
Old 10-13-07, 07:20 PM
my name is Tiffany
Cadillac(s): 05 CTS-V
View urbanski's Photo Album
Casino Cash: $1133630
Re: Northstar Crankshaft Position (CKP) Sensor replacement
keep questions out of tech tips
http://www.cadillacforums.com/forums...here-they.html (DO NOT post questions here, they will be DELETED)
  #10 (permalink)
Old 10-14-07, 10:22 AM
FrankT's Avatar
Cadillac(s): 99 STS
Casino Cash: $7629
During a learn procedure the PCM/ ECM learns the amount of crankshaft position (CKP) system variation. If a crankshaft variance relearn is not performed, then there is a chance of setting codes.
  #11 (permalink)
Old 10-14-07, 11:57 AM
Casino Cash: $13342
http://www.cadillacforums.com/forums...placement.html (Northstar Crank Sensor replacement)
This thread is a duplicate and the short version. The one above is the real one.
  #12 (permalink)
Old 10-15-07, 08:48 AM
Casino Cash: $13342
I found this on a NON GM site, but it looks correct.
NOTE: If the Crankshaft Variation Relearn is not accessible through your scan tool (some truck applications 1998 & later), perform the relearn in the following manner:
1. Turn off all of the accessories. With the Air temperature sensor and Coolant temperature within 5 degrees (Centigrade) of each other, start the engine and let it idle in Park or Neutral for two minutes.
2. Accelerate the vehicle to 55 mph at part throttle. Cruise at 55 mph for 8- 10 minutes until the engine reaches operating temperature.
3. Cruise at 55 mph for another 5-6 minutes.
4. Decelerate to 45 mph without using the brakes, and maintain 45 mph for 1 minute.
5. Perform 4 deceleration cycles, without using the brakes, of 25 seconds each where no specific speed is necessary. Returning to 45 mph for 15 seconds in between deceleration cycles.
6. Accelerate to 55 mph and cruise for 2 minutes.
7. Stop the vehicle and idle for 2 minutes with the brake applied and the transmission in Drive.
  #13 (permalink)
Old 10-15-07, 09:35 PM
codewize's Avatar
Cadillac Owners Master
Cadillac(s): 1989 STS / 2001 DTS / 2002 DTS
View codewize's Photo Album
Casino Cash: $14180
oops sorry. Posted in the wrong window.
Ownership:
89 STS (1 of 1893) - FOR SALE
02 Blue Onyx DTS
01 DTS:
Custom installed Volant CAI
Custom PCM
Body color engine components
Cruiser Alloy wheels
EBC brakes
Eibach springs
Corsa exhaust
Sportwing Spoiler
Semi-custom interior
Custom quad Hi-Beams
Future Plans: More interior work.
Memberships:
National and regional Cadillac & LaSalle Club
Proud Volunteer - Northstar Tuning Project
  #14 (permalink)
Old 10-15-07, 10:11 PM
Casino Cash: $13342
Tags: , , , , ,
ckp, crankshaft, northstar, position, replacement, sensor
