Northstar Water Pump Replacment Steps - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Like Tree1Likes
Cadillac Tech Tips - How to fix it Discussion, Northstar Water Pump Replacment Steps in Item Specific Cadillac Discussion; Thank you for the great write up on changing the water pump. I just finished in my 2004 Seville, took ...
  1. #31
    seville04 is offline Cadillac Owners Member
    Automobile(s): 2004 Seville
    Apr 2011
    7
    Re: Northstar Water Pump Replacment Steps
    Thank you for the great write up on changing the water pump. I just finished in my 2004 Seville, took 3 hours, but that included lunch, two trips to the auto parts store and a half hour of trying to unseat the pump while turning it counter clockwise, Doh! Thanks again for the instructions, Advance and Autozone did not loan the tool so I bought one from Advance for $30, the water pump was $45 and the seal was $4.
  2. #32
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,969
    I wonder if a note should be made about changing the pump housing/cover to update to the new style with that awesome picture that shows the two styles
    and also it should be noted that the thermostat housing gasket also has to be changed to the thicker style (from #3522676 to #12574478) when upgrading to the new pump housing/cover
    or maybe just find a way to merge this thread and this one: http://www.cadillacforums.com/forums...p-removal.html
  3. #33
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,816
    New w/p housing cover and gasket - designed to stop delayed leaks.
  5. #34
    The Frugie's Avatar
    The Frugie is offline Cadillac Owners Member
    Automobile(s): '95 Eldorado
    Mar 2010
    whOrlando
    36
    17
    I wanna thank ipncjh1 and everyone who has contributed to this thread. It's been a great help in replacing my water pump. I've run into a hangup though. I can't get the new w/p on. It took me the longest to figure out the correct orientation (it's 1 o'clock, not 7 o'clock like the ACDelco instructions said). But even after I figured that out I still couldn't screw on the new pump and ended up bending the tangs.
    So I bought another w/p and tried screwing it on without the o-ring. Finally it fit. But I can't leave it like that. So what should I do, get a thinner o-ring, use a razor or something to scrape off part of the o-ring I have? Has anyone else run into this problem?
  6. #35
    Feb 2006
    56,816
    Did you lube the O-ring with raw coolant ???? - and it MUST be installed as-is - no scraping or resizing is possible or desired......... and did all the original ring come out of the water pump housing ?
  7. #36
    The Frugie's Avatar
    Mar 2010
    whOrlando
    36
    17
    I finally got it in. It turned out some of the old o-ring was still on there. My aunt and her husband were visiting and he took a look at it. The first thing he asked for was a flat head screwdriver. I don't know why I didn't think of that. I scraped off as much as I could using a razor, steel wool, and even my finger nail. But the screwdriver ended up being perfect for the job.
  8. #37
    GeorgeT is offline Cadillac Owners Member
    Automobile(s): 1998 DeVille
    Sep 2013
    4
    I'm having a BEAR of a time getting the 4th, bottom right hand bolt out of the WP cover. There's black covered wire or something impeding the socket going on straight. Any suggestions? 98 DeVille. Thank you!
  9. #38
    Mojo88's Avatar
    Mojo88 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 White Diamond DeVille 'Base'
    Dec 2011
    Newport, RI
    65
    347
    Just did mine. Surprisingly easy. The special tool worked like a charm. The hardest part was cleaning the o-ring area, and also cleaning the housing gasket area, then replacing both seals.
  10. #39
    Thecaday is offline Cadillac Owners Member
    Automobile(s): 2001 STS
    May 2013
    7
    I just wanted to add that for my Cad a 01 STS this was a lot more difficult than the standard model described here-at least in my case there was some kind of EVAP canister in the way, wasn't too much more difficult but different-I'm fortunate to have medium sized hands as I could just barely fit my 10mm wrench in there but I got it- sometimes working on my head but you can do it- if your having problems taking off the pulley cover you gotta take off the EVAP canister first- there's also a screw that holds a plate that holds onto the dipstick/evap device you need to separate- it's kind of hidden in the bottom/middle of the plate.
    What was really difficult and no one mentioned this was lining up the waterpump to go back- some folks said 7o'clock some on the internet said 1PM, apparently there BOTH right depending on the model but the sure fire way to line it up is you'll have a tab on your waterpump with a open circle on it different from the other tabs- if you look at where the waterpump is supposed to go- there will be a small circle cropping out about the same size as the tab's circle-THAT is where it's supposed to go.
  11. Remove Advertisements
