I took the regulator out, seen my cable was rat nested and kinked, took off the motor, drilled out the rivets holding the cable guide spool together (use 5/16" x 1/2" long machine bolts to replace rivets, can access 3 out of 4 rivets drilled, but will be plenty to hold guide in place), bought new 1/16" cable and 1/16" cable stops (need 7' cable $0.26 per foot, stops $1.24 per bag at L_o_w_e_s). When taking apart, pay close attention to notice a short and long side of the cable beyond the middle cable stop that carries the window clamp and the cable covers are also different lengths, the short one going to the bottom side of the regulator, long to the top. As far as the window clamp (which had the busted white plastic lock down for the middle carry stop) if you look close you'll see two metal tabs looking up at you where the plastic broke (might have to break away a little more plastic to reveal), I just folded them over onto the new cable to lock the middle stop in place and works better than ever, total fix for all 4 windows $12, just took more time with panels than fixing regulator.
The whole regulator comes apart pretty self explanatory, I mean if its broke to begin with, and plan to buy a new one anyway, what is there to lose in breaking it down. The hardest part I had was adjusting the cable for its proper length between the stops. I found putting the window clamp all the way down, and winding the cable up 4 wraps on the blue spool, saving 1 wrap for the opposite end of the cable gives you 6" per wrap and there's only 1' 4" of total (rear) window travel. Be sure to have the window clamp all the way down, and when wrapping the spool you'll have to set the lower cable cover so the spring that goes into the black cable guide is almost completely compressed, if not, it allows too much slack in the cable and will just backlash again or reverse onto the spool and more than likely kink again leaving you starting all over again. Good luck, hope this helps some for the do it your selfer like myself.
