DeVille Window Regulator/Motor Repair - HOWTO pdf - Page 9
Page 9 of 11 FirstFirst 1234567891011 LastLast
Results 121 to 135 of 151
Like Tree25Likes
Cadillac Tech Tips - How to fix it Discussion, DeVille Window Regulator/Motor Repair - HOWTO pdf in Item Specific Cadillac Discussion; How did those hold up? I just bought an 03 Deville with this issue....
  1. #121
    productionx is offline Cadillac Owners Member
    Automobile(s): 2003 Deville Base, 97 Seville STS[currently deceased]
    Oct 2010
    32
    5
    Re: 2000 Deville Window Regulator Fix
  2. #122
    cadillacforumsJKS is offline Cadillac Owners Member
    Automobile(s): 2000 Deville
    Mar 2012
    57
    1
    Re: DeVille Window Regulator/Motor Repair - HOWTO pdf
    I am on my 12th regulator. All windows have been replaced at least twice, with some 3 times. I bought regulators only for about $40. I am getting to be an expert on taking them out - I can make the repair in about 30 minutes. This time, I think I will try the cotter-key method instead of buying another regulator (this last one worked for abnout 2-1/2 years before failing again).
  3. #123
    stinger161 is offline Cadillac Owners Member
    May 2011
    47
    Well just did the cotter pin fix and after some test runs before buttoning everything back up it worked about 5 times and something gave again. So gotta tear everything back apart and see what it was.
  5. #124
    Dadcad is offline Cadillac Owners Member
    Automobile(s): 2004 Deville DHS
    Feb 2011
    Re: 2000 - 2005 Deville Window Regulator Fix
    The cotter pin fix is great. I have done two on my 2004 Deville. No problems whatsoever. You probably know that you have to remove the lifter arm from the track to do this repair. The lifter arm runs on the track at three (plastic tab) points. My only caution here is that you remove the arm by applying gentle pry pressure on the small single tab while applying gentle pressure on the lifter arm to move it away from that side of he track. Once it clears its side of the track, you just gently fold the whole arm towards the other two plastic runners. You don't have to remove the arm at that point since you just need enough space to put the cotter pins in place,, but you can if you wish. The most critical part of the whole job has nothing to do with the regulator. You MUST be very careful to remove the door trim panel by placing the trim removal tool EXACTLY at each trim attachment point as shown in the service manual. If you don't, I GUARANTEE you will break your trim panel anchor points! BTW, I have been running my cotter pin repaired regulators for two and three years respectively.
  6. #125
    venomz is offline Cadillac Owners Member
    Automobile(s): 2006 DTS Performance
    Aug 2011
    Easley, SC
    37
    50
    I supplemented the cotter pin fix by making bushings to keep the pins and the cable from rubbing together. I picked up some 5/16 nylon fasteners from Lowe's, cut a slit down one side so that I could slide it over the cable, used the heads of the cotter pins to clamp the fasteners together again, and then proceeded to do the rest of the repair per instructions.
    I just wanted to share this solution to the potential problem of the pins wearing through the cable.
  7. #126
    yellow1 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jun 2008
    24
    Best idea since sliced bread. Thanks for the great tip. Have now done two windows and both work great!!!!
  8. #127
    eagle9 is offline Cadillac Owners Member
    Automobile(s): 2000 deville
    Sep 2012
    11
    was driving home today. while rolling driver door up, heard some grinding and a pop. im assuming its the plastic part breaking. gonna try the cotter pin trick. WHERE on the door panel would i put a screw driver or other device to remove the door panel without breaking the clips??? thanx.
  9. #128
    69
    82,262
    There is another thread (in Tech Tips) that explains the panel removal.
  10. #129
    Sep 2012
    11
    thanx, gonna try this repair in the morning. hope its simple. i only have ONE window that works now. when i bought the car, the rears didnt work. i didnt care, just rolled the front down when it got hot and i didnt wanna run the air. gotta at least fix this driver window..............smh
  11. #130
    phopkins is offline Cadillac Owners Member
    Automobile(s): 2001 DTS, 2008 DTS
    May 2012
    Thanks so much lowscola for the "how to". I ordered my motor/regulator from Window Motor World for $135.00 shipping included to Canada. The job took just over an hour and my 2001 DTS was back in business without breaking anything. You deserve a big "Atta Boy". Thanks again.
  12. #131
    Sep 2012
    11
    Well, about about 3 hours of trying to get ONE stripped nut that mounts the regulator to the door frame loose, i was too frustrated to try the cotter pin trick and just went ahead and purchased a regulator for 90 dollars at o reilly's...... Door went back together in 15 minutes after all that turmoil.......
  13. #132
    Sep 2012
    11
    one more thing, even though i went ahead and bought the regulator, i still SAVED money by learning how to remove that panel myself. ive got two more windows that are broke, so, at the worst, i can buy the parts and still come out ahead...........
  14. #133
    ott4deville is offline Cadillac Owners Member
    Oct 2012
    1
    Great info, my RR regulator went four months ago.. replaced with a new one and did not do the cotter pin trick.. This time I'm doing the cotter pin trick on my LR regulator that just did the pop and drop as well..
    Thanks again!
  15. #134
    cadillacpaco is offline Cadillac Owners Member
    Automobile(s): DeVille
    Oct 2012
    63
    1
    If you are going to just tape it up make sure to use painters tape. It is the blue colored masking tape. Any other tape will take days to come off after baking in the sun... If your in the Orlando area make sure to use Power Window Repair 407-415-5401. The owners name is Bob and is a super nice guy and gets the parts factory direct and cost far below 1/2 of what the stealerships charge for the parts and installation. They even cheaper than the jerks who say the rebuild your broken parts [with super glue and pipe cleaners] Orlando Power Window Repair did all my windows.
  16. #135
    ORCoastGuy is offline Cadillac Owners Member
    Automobile(s): 2001 DeVille DTS
    Aug 2011
    Oregon, USA
    47
    Several years since the first post in this thread, and I just wanted to say that I used all the above info. to solve this exact same problem tonight. This is by far the most useful, and well-contributed post I've ever read about ANY topic in ANY forum. THANK YOU to each and every one of you who contributed to this post!
    I've had my '01 Deville DTS door panels off previously for another reason, so I was familir with that process, making the removal of the regulator arm an absolute cinch! It took me longer to run to the hardware store for some cotter pins, and to fit/bend them into place on the lifting arm working on the kitchen table, than it did for me to take the regulator arm out and put it back in. Working great now! Easily a $300-$600 mechanic bill saved by $0.55 in cotter pins!!!
  17. Remove Advertisements
