DeVille Window Regulator/Motor Repair - HOWTO pdf - Page 8
Page 8 of 11 FirstFirst 1234567891011 LastLast
Results 106 to 120 of 151
Like Tree25Likes
Cadillac Tech Tips - How to fix it Discussion, DeVille Window Regulator/Motor Repair - HOWTO pdf in Item Specific Cadillac Discussion; That thing is just achored to the middle area of the door. Don't pull on it. LIFT it off....
  1. #106
    69
    82,265
    Re: DeVille Window Regulator/Motor Repair - HOWTO pdf
  2. #107
    Dave NYC's Avatar
    Dave NYC is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville (Base)
    Mar 2007
    New York City
    48
    185
    Thumbs upRe: DeVille Window Regulator/Motor Repair - HOWTO pdf
    Correct......
  3. #108
    Breeze454's Avatar
    Breeze454 is offline Cadillac Owners Member
    Automobile(s): 2001 Deville 1965 Coupe Deville
    May 2009
    North Florida
    33
    Re: 2000 Deville Window Regulator Fix
    Just did the cotter pin fix to a reg I replaced a year ago, that just broke again, perfect solution, good work ELI ICE.
  5. #109
    bevdaily is offline Cadillac Owners Member
    Automobile(s): 2004 DeVille
    Mar 2009
    my right rear (passenger side) window fell. My son attempted to open panels. He got the outer panel off successfully but is concerned about the wiring connection. He says it "looks" like he would have to cut wires and is not willing to do that. Can you help?
  6. #110
    8.2liter is offline Cadillac Owners Member
    Automobile(s): 2003 DES yes DES
    Dec 2006
    23
    Thanks ELI ICE. Borderline genius. Now somebody needs to sell a kit online containing 2 cotter pins for $19.95. Seriously, luckily I had the Gorilla black duct tape in the "03 DES yes DES for the automatic window drop 40 minutes from home in a balmy 88 degrees. So keep the duct tape in the trunk if you have any plastic regulators in play.
  7. #111
    DSNCB919 is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac Seville 2003 Cadillac DTS 2010 DTS Platinum
    Jun 2009
    North Carolina
    28
    538
    Im attempting the cotter pin fix but Im a bit confused, okay for one when I got my regulator out I realized that the top wheel of the pulley system the wire isant overtop of it as it should be and its way to tight to pull it over the pulley, other than that my regulator looks fine but where do I put the cotter pins exactly? like in the imagine it looks like they are on the beed but then it looks like they are on the part of the regulator that goes up and down.. can someone please explain in detail?
  8. #112
    jimalicia is offline Cadillac Owners Member
    Automobile(s): deville
    Aug 2011
    1
    Man, I would be happy to buy the gent that posted the cotter pin fix above! 1.98 to repair the RR, too bad I didn't know this for the first 3!
  9. #113
    Leeho is offline Cadillac Owners Member
    Automobile(s): 2000 Deville DHS
    Sep 2011
    62
    1
    I just fixed my Driver side window with the cotter pin method. Working so far. Also had to remove the cable gearbox the motor is mounted on to re-string the cable that had come off the spool inside the gearbox. I drilled out the rivets holding the gearbox to the frame, then replaced the rivets with 10-32 screw and nut. (only replaced 3 of the 4- the 4th screw interfered with the motor mounting flush to the frame.
    THANKS TO ALL FOR THEN INFO ON DOOR PANEL REMOVAL(Lowcola) AND COTTER PIN REPAIR! Easy to follow and such complete information.
  10. #114
    BigDaddy63's Avatar
    BigDaddy63 is offline Cadillac Owners Fanatic
    Automobile(s): 2002 Cadillac Deville DTS
    Mar 2008
    211
    My damn driver side regulator popped for the FOURTH time in 3 years, so I did the cotter pin repair. Other than a little play, it seems to be working fine and should actually be stronger than the stupid plastic piece GM decided to use for a 60K car.
    Now, for about 30 cents I can fix this problem in the future
    Thanks again
  11. #115
    ninefinger is offline Cadillac Owners Member
    Automobile(s): 2002 Deville
    Oct 2011
    46
    1
    I just fixed the regulator on my 2002 Deville using the Cotter Pin trick. Except I didn't have any cotter pins handy so I made some out of #10 solid copper wire. Seems to be a very stable fix. Thanks again to all in this forum. Great ideas that save me lots of money and time.
    wessongroup and wessongroup like this.
  12. #116
    cloudsts98 is offline Cadillac Owners Member
    Automobile(s): 1998 cadillac sts
    Oct 2011
    great tip. im going to try this during the weekend. i did already take my door panel off and looked at the regulator because i need to hold the window up somehow. i noitced the cable is kinked (bent or twisted) will this still work? im wondering if its going to get stuck in the motor becuse its twisted.
    also any ideas on how to stop the slack in the window? thx guys!
  13. #117
    aamir209 is offline Cadillac Owners Member
    Automobile(s): Deville DHS
    Nov 2011
    26
    Please help i can't find the pdf when i click on the link it doesn't work. What should i do?
  14. #118
    jralvara is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac Deville DTS
    Nov 2011
    1
    I have the same problem as aamir209, the link to the pdf is dead. Could someone re-up it? Thanks!
  15. #119
    69
    82,265
    I PM'd the OP to repost it if he can, but he hasn't been here since 10/11/11.
  16. #120
    bhuntington is offline Cadillac Owners Member
    Automobile(s): 2004 Deville
    Nov 2011
    1
    Quote Originally Posted by cepeda0812 View Post
    This link does not work and I desperately need to replace the window lift motor in my deville which just broke on me about an hour ago. I appreciate any help thank you
    I had same problem trying to access the pdf file myself until I registered as a forum member. Once you've created an account, log in and links/attachments referenced in threads will then be fully accessible.
  17. Remove Advertisements
