DeVille Window Regulator/Motor Repair - HOWTO pdf - Page 3
Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 31 to 45 of 151
Like Tree25Likes
Cadillac Tech Tips - How to fix it Discussion, DeVille Window Regulator/Motor Repair - HOWTO pdf in Item Specific Cadillac Discussion; good question. i think gm has to keep the mechanics busy. and i know labor rate here is 95 per ...
  1. #31
    jcdsog is offline Cadillac Owners Member
    Oct 2003
    sc
    40
    24
    Re: 2000 Deville Window Regulator Fix
    good question. i think gm has to keep the mechanics busy. and i know labor rate here is 95 per hr. i mean think about it... we got a rover on mars.
  2. #32
    garretthes's Avatar
    garretthes is offline Cadillac Owners Member
    Automobile(s): 2000 DHS
    Feb 2006
    41
    Re: DeVille Window Regulator/Motor Repair - HOWTO pdf
    Thanks for all the help guys. I was able to repair mine using epoxy. If it fails again I will do the sheet metal trick. It sounds way more stable.
  3. #33
    pohen2222 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jul 2008
    1
    Great Instructions! Repaired in less than an hour and saved myself about $360(Repair shop quoted $561 to replace. The part was $414 alone!) by ordering through Window World!
  5. #34
    2KDHS is offline Cadillac Owners Member
    Automobile(s): White Diamond DHS
    Aug 2007
    Indiana
    9
    SmileRe: DeVille Window Regulator/Motor Repair - HOWTO pdf
    Thank You for putting such a good step by step on replacing the regulator assy. The dealer wanted $550.00. I got one from Window Motor World for $150.00 and it took 1½hrs to do the job myself with your pdf.
    THANKS AGAIN!!!
  6. #35
    skippydts's Avatar
    skippydts is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS AWD - Black inside and out
    Apr 2008
    53
    285
    Let me add my thank you.
    Your PDF gave me the courage to do-it-myself. I paid about $110.00 for two regulators online. One from Partstrain, Autopartswarehouse. I must have save $600.00 based on what I have read here.
    I had two regulators go out within two weeks.
    Thanks
  7. #36
    arkgideon is offline Cadillac Owners Member
    Sep 2008
    1
    I managed to find a regulator online for a total of 55.00 including the shipping and was able to install i less than one hour. The .pdf file located in the forum was very helpful, thank you. The dealer wanted 670.00 to replace the regulator, which I feel is a total rip-off.
  8. #37
    mrgoodbar67's Avatar
    mrgoodbar67 is offline Cadillac Owners Enthusiast
    Automobile(s): 2002 Cadillac DTS Deville on Vogues and DTS Blades
    Jul 2007
    Bell, CA
    33
    605
    I FIXED MINE WITH EPOXY AND WORKS PERFECT.
    SAVED MYSELF $490 COMPARED TO DEALER REPAIR OR BUYING A NEW REGULATOR.
    THANKS FELLAS.
    HERE A FELLOW MEMBER HAVING PROBLEMS, SEE IF WE CAN HELP.
    http://www.cadillacforums.com/forums...ave-issue.html
  9. #38
    ELI ICE is offline Cadillac Owners Member
    Automobile(s): DeVille
    Dec 2008
    53
    1
    This was a good recommendation and it got me thinking. I ended up using a couple of cotter pins. Take a look.....
  10. #39
    Jul 2007
    Bell, CA
    33
    605
    cotter pins look good.....ill try that next time. I already replaced 2 on my dts.
  11. #40
    dts2002 is offline Cadillac Owners Member
    Automobile(s): 2002 dts
    May 2009
    It looks quite easy. how is it made? how many inches andwhere they are bent?
  12. #41
    May 2009
    how is it made?
  13. #42
    K@ddiD@ddi's Avatar
    K@ddiD@ddi is offline Cadillac Owners Member
    Automobile(s): 2000 Deville
    May 2009
    41
    89
    I have had all of my windows break doing the same thing, I have fixed my windows by making the little metal straps to go around the steel ball but I do suggest making sure that the only thing that touches this piece is the metal ball, as mine wore through the cable and snapped it. Does anyone have an easy fix for the cable??
  14. #43
    Jul 2007
    Bell, CA
    33
    605
    Well ima try that cotter pin thing now.
    My rear driver side door window failed and i bought a new reg on ebay about a year ago and has worked good.
    Right after that my driver door window failed. Replaced that one too and yesterday it failed again........cotter pins here i come.
  15. #44
    Jul 2007
    Bell, CA
    33
    605
  16. #45
    K@ddiD@ddi's Avatar
    May 2009
    41
    89
    Ok the cable is fixable, I took mine apart, not successfully though I broke the plastic housing where the motor mounts to, I also didnt fix it because my cable was stuck inside the housing and it was a tangled mess, but if anyone is starting to get frayed cables go ahead and take the time to very carefully pull the housing apart and take note of how the cables work because both ends attach to the wheel that is on the inside of the housing, you just have to pay attention to which cable is on which side and how many times it goes around the wheel. The cable and the cable ties are available at home depot for about $10.00, it looks easy enough, 1 cable, 1 wheel. If you can change a tire, you can fix the regulator!!
  17. Remove Advertisements
