DeVille Window Regulator/Motor Repair - HOWTO pdf - Page 10
Page 10 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 136 to 150 of 151
Like Tree25Likes
Cadillac Tech Tips - How to fix it Discussion, DeVille Window Regulator/Motor Repair - HOWTO pdf in Item Specific Cadillac Discussion; Hey I couldn't find the cotter pin fix guide from the links posted in this thread. Says it's invalid link. ...
  1. #136
    Trendz1911 is offline Cadillac Owners Member
    Automobile(s): 2002 Cadillac Deville
    Nov 2012
    28
    1
    Re: DeVille Window Regulator/Motor Repair - HOWTO pdf
    Hey I couldn't find the cotter pin fix guide from the links posted in this thread. Says it's invalid link. Any help? My regulator broke and it's been raining here so I have to cover my window with a plastic bag
  2. #137
    mrgoodbar67's Avatar
    mrgoodbar67 is offline Cadillac Owners Enthusiast
    Automobile(s): 2002 Cadillac DTS Deville on Vogues and DTS Blades
    Jul 2007
    Bell, CA
    32
    605
    funny that this always happened to me when it rained. instead of using a bag..i just jammed a magazine between the window and the inside of the car weather stripping and it forced enough pressure on the window to keep it up.
    hope it helps in the meantime.
  3. #138
    DENNISUE is offline Cadillac Owners Member
    Feb 2013
    58
    1
    We are interested in your sheet metal fix please! Thanks
  5. #139
    MuRCieLaGo is offline Cadillac Owners Member
    Automobile(s): DeVille 2001
    May 2013
    28
    16
    It would be awesome to have a nice DIY tutorial for cotter pins... I'll try anyway to fix the regulators with my two left hands!
  6. #140
    Dave NYC's Avatar
    Dave NYC is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville (Base)
    Mar 2007
    New York City
    48
    185
    For folks that simply want a new reliable regulator for your Caddy, you can get them for as low as $25 on the link below, it comes brand new with motor. I bought 2 of these at different times, 1 for the drivers side and left rear passenger over 3 years ago and they work like a champ.
    Take a look,
    http://tinyurl.com/blf6ygp
  7. #141
    ORCoastGuy is offline Cadillac Owners Member
    Automobile(s): 2001 DeVille DTS
    Aug 2011
    Oregon, USA
    47
    Update: My cotter pin fix worked for 5 months, then gave way. The reason: I didn't use heavy-enough gauge cotter pins! The regulator pulls the window up and down with significant force. Over time, that force bent the cotter pins such that they pulled right through the holes on the arm they were bent around. So I have performed the same operation again, this time using larger, stronger cotter pins. My advice is to use the largest (heaviest gauge) cotter pins you can find that will still fit through the holes in the arm. Working great once again, and I have much more confidence in this solving the problem for the car's final years. (12 yrs. old now, I don't plan to keep it many more)
  8. #142
    txoilman8 is offline Cadillac Owners Member
    May 2013
    40
    1
    I took the regulator out, seen my cable was rat nested and kinked, took off the motor, drilled out the rivets holding the cable guide spool together (use 5/16" x 1/2" long machine bolts to replace rivets, can access 3 out of 4 rivets drilled, but will be plenty to hold guide in place), bought new 1/16" cable and 1/16" cable stops (need 7' cable $0.26 per foot, stops $1.24 per bag at L_o_w_e_s). When taking apart, pay close attention to notice a short and long side of the cable beyond the middle cable stop that carries the window clamp and the cable covers are also different lengths, the short one going to the bottom side of the regulator, long to the top. As far as the window clamp (which had the busted white plastic lock down for the middle carry stop) if you look close you'll see two metal tabs looking up at you where the plastic broke (might have to break away a little more plastic to reveal), I just folded them over onto the new cable to lock the middle stop in place and works better than ever, total fix for all 4 windows $12, just took more time with panels than fixing regulator.
    The whole regulator comes apart pretty self explanatory, I mean if its broke to begin with, and plan to buy a new one anyway, what is there to lose in breaking it down. The hardest part I had was adjusting the cable for its proper length between the stops. I found putting the window clamp all the way down, and winding the cable up 4 wraps on the blue spool, saving 1 wrap for the opposite end of the cable gives you 6" per wrap and there's only 1' 4" of total (rear) window travel. Be sure to have the window clamp all the way down, and when wrapping the spool you'll have to set the lower cable cover so the spring that goes into the black cable guide is almost completely compressed, if not, it allows too much slack in the cable and will just backlash again or reverse onto the spool and more than likely kink again leaving you starting all over again. Good luck, hope this helps some for the do it your selfer like myself.
  9. #143
    Dave NYC's Avatar
    Mar 2007
    New York City
    48
    185
    Did we evrr figure out why my posts are being moderated on some theads/sections? Thanks.....
  10. #144
    MrKinetik is offline Cadillac Owners Member
    Automobile(s): Deville
    May 2009
    Indianapolis
    31
    9
    This thread has been a great resource. I did the cotter pin fix on my 2004 Deville and now the window is a little noisy when I roll it up and down which I guess is because of the cotter pins running along the track. Not sure if there's anyway to fix the noise BUT I can roll the window up and down. It's the passenger side anyway and I very rarely roll it down so it's all good. Beats buying a regulator. I can put that money into these door speakers. Might as well upgrade while I have the panel off!
  11. #145
    KCProper357 is offline Cadillac Owners Member
    Aug 2013
    1
    I have found a place on the web that sells both the regulator/motor assy or just the regulator...autopartswarehouse.com.....OEM parts, wwwaaayyy below dealer cost!!
    KamD450 likes this.
  12. #146
    monty_n_philly is offline Cadillac Owners Member
    Automobile(s): 03 Deville, DTS
    Apr 2013
    41
    69
    I did mine about 4 months ago,, passenger rear... I bought a new one for $33... and found this video and did it myself in about 1 hr.. this video is perfect... it takes 10 mins to do it now..
    https://www.youtube.com/watch?v=S2qsjXrzmgA
  13. #147
    GeoGoGo is offline Cadillac Owners Member
    Automobile(s): 2000 Deville
    Jan 2005
    Upstate NY
    46
    72
    I know this is an old thread but does anyone have a copy of the .pdf from the 1st post? Surprisingly after 5 years, the link doesn't work! Thank you all in advance.
  14. #148
    mmantov is offline Cadillac Owners Member
    Automobile(s): 2004 Deville
    Mar 2014
    1
    Thank you to everyone for the advice. I just completed this repair today using the cotter pin method. All I would add is that between the cotter pin and the "knob" on the wire, I used some small split-lock washers I had lying around. They slipped over the cable and I gently squeezed them to be sure they don't slip off. I used about 6 of them. A second option would be to wind some thick copper wire around the cable. This way there is no slack.
    Only problem I had was that I broke a few plastic fasteners that hold the interior door panel and soundproofing panel in place. Plastic should be outlawed in the manufacture of cars!
  15. #149
    Shop Girl is offline Cadillac Owners Member
    Automobile(s): Sedan De Ville
    Apr 2014
    1
    Yes I would like the instructions to fix.
    __________________________________________________ ______________
    Your CF account is validated. please go back through this thread and others in Tech Tips to find instructions. It's already posted in here and up in Deville.
  16. #150
    carpercarol is offline Cadillac Owners Member
    Automobile(s): 2006 DTS
    May 2014
    Did you get your window fixed? we can't figure out how to remove the door panel. Do you know how?
    Thanks
  17. Remove Advertisements
