01 Eldo Coolant changing tips - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Cadillac Tech Tips - How to fix it Discussion, 01 Eldo Coolant changing tips in Item Specific Cadillac Discussion; I have two questions, 1) How do you dispose of the old coolant properly and 2) I have a 01 ...
  1. #16
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Re: 01 Eldo Coolant changing tips
    I have two questions, 1) How do you dispose of the old coolant properly and 2) I have a 01 DTS, how difficult is it to get the lower hose off.
    I guess I have a third question now. Is 50/50 the proper ratio to mix? I haven't read the manual on this yet and it almost seems worth the $90 for the dealer to do this.
  2. #17
    68
    82,064
    50/50 is the proper mix. Lower hose is hard to get at. That's why I put the tabs in the upper. Not hard to find someone who will take used oil but I have found it almost impossible to get rid of coolant.
  3. #18
    Patrick7997's Avatar
    Patrick7997 is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 Escalade, 07 Road King, 08 Challenger SRT8
    Oct 2005
    Pewaukee, Wisconsin
    53
    712
    There's a Pennzoil oil change place near my house, and they also do coolant changes... They will take your used coolant. For some reason, they are adament that they do NOT want the containers... they pour the jugs in their waste tank, and give me back the empty jugs....
    As for the coolant tabs, I pre-dissolved them, as the original post stated, and poured that mix in the overflow bottle... worked out fine. Pre-dissolved in the FIRST HALF GALLON that I added, and then "chased it down" with pure 50/50 mix....
  5. #19
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Patrick, How did you drain? Petcock?
  6. #20
    Oct 2005
    Pewaukee, Wisconsin
    53
    712
    Sorry Codewize, I've been a little busy.
    Yes, I did the petcock. Takes awhile, but it works, and it's pretty easy. Lowering the car off the jack will get more coolant out... I pretty much did exactly what's in the original post.
    As far as possibly not getting "all" the coolant out, my intention is to do it again in fall.... probably overkill, but it only cost $20-some bucks to do it myself.... costs me $15 in gas to go to work... so, make of it what you will, $20 to be sure I'm good seems like cheap insurance.....
  7. #21
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    How did you derive at 5 1/16 " long on the dowel. That seems pretty precise. Why would there be a length problem here. Wouldn't 6" have been fine? I'm going out to do this today but I also got a 3/4 dowel rather than 7/8 because I thought I read that. I guess it will still work.
  8. #22
    68
    82,064
    3/4" dowel will work just fine. Length is not critical. Just has to be long enough to reach the plug.
  9. #23
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Wow that was quick. One more silly question. Looking at it from the bottom, turning counter clockwise will open ?
  10. #24
    68
    82,064
    Same as any other bolt. Righty tighty, lefty loosy.
  11. #25
    EDBSO is offline Awaiting Email Confirmation
    Mar 2006
    332
    Quote Originally Posted by JimHare
    If I wanted a damn SR-71, I'd have bought one.
    If you are flexible on delivery time then ... Let me know. EDBSO
  12. Remove Advertisements
