2000 STS Northstar Propane/LPG conversion - Europe
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Submariner409
Cadillac Tech Tips - How to fix it Discussion, 2000 STS Northstar Propane/LPG conversion - Europe in Item Specific Cadillac Discussion; Hello all, Last year I've converted my STS to Propane/LPG. My goal was to install a liquid propane injection set ...
    Jan Kraakman's Avatar
    Jan Kraakman is offline Cadillac Owners Member
    Automobile(s): 2000 STS pearl white, my long time dream :-)
    Feb 2005
    Netherlands Zwaag
    6
    Hello all,
    Last year I've converted my STS to Propane/LPG. My goal was to install a liquid propane injection set due to my understanding that injecting the propane as a liquid in the intake like gasoline it would cool the mixture leading to an increased charging of the cylinders (no power loss) and eventually cooler burn temperatures (less temp. stress on valves etc.) compared to vapor injection. After searching the web I came to two brand options, Vialle and Icom. Since Vialle only allows their dealers to install their product and I, run my own shop for +32 years, wanted to install it myself the choice was easily made. Although the JTG2 system http://www.icomnorthamerica.com/jtg-ii-bi-fuel-3 is a fairly simple instal and adjust, I had to overcome some minor difficulties. I wanted the fill valve behind the gasoline fuel filler door but to gain acces from the inside of the trunk to the fuel filler housing I had to cut out / get thru the body inner metal. The filler valve and hose are not Icom btw but temporally.
    Feb 2005
    Netherlands Zwaag
    6
    Re: 2000 Seville/STS Northstar Propane/LPG conversion.
    I then started to install the 86 liter tank with intern fuel pump. But before I could I had to relocate the radio receiver that was mounted in the bracket behind the navigation unit.
    IMG_1937.JPG IMG_2008.JPG IMG_2010.JPG IMG_2011.JPG IMG_1956.JPG IMG_1957.JPG IMG_1958.JPG
    Submariner409's Avatar
    Submariner409 is online now If it won't run, chrome it
    Feb 2006
    MD Eastern Shore, Kent Island
    56,825
    Nice work, Jon. Due to the extremely limited use of LPG in U.S. converted motor cars, I'll move your (ongoing ?) tutorial down to a permanent home in Cadillac Tech Tips.
    Welcome to the Forums !!!!
    Jan Kraakman likes this.
    Feb 2005
    Netherlands Zwaag
    6
    Re: 2000 STS Northstar Propane/LPG conversion - Europe
    Thanks Submarine,
    Here's the final tank install https://plus.google.com/photos/10843...72854933847805
    I'll be posting more as soon as possible
    Jan.
    PontiacV8's Avatar
    PontiacV8 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Camaro 2SS, Sold: 2006 STS (EXP) 1997 Seville STS (EXP)
    Dec 2006
    Germany / Nordhorn
    423
    Quote Originally Posted by Jan Kraakman View Post
    ...link doesn't "work"...( google+ account needed...!!)
    ...btw....why didn't you use a toroidal tank (stako etc.) in the spare wheel area? (...to save some more space in the trunk)
    Feb 2005
    Netherlands Zwaag
    6
    I've changed the sharing option in Picasa so it should work now, I've tried it on my wife's computer
    The reason not using a toroidal tank was that the spare wheel space wasn't deep enough and the tank would be to small if I did
    Jan.
  9. Remove Advertisements
