2002 Deville Air Temperature Actuator Replacement
Results 1 to 14 of 14
Like Tree2Likes
  • 2 Post By Ranger
Cadillac Tech Tips - How to fix it Discussion, 2002 Deville Air Temperature Actuator Replacement in Item Specific Cadillac Discussion; Greetings, I just replaced a faulty air temp actuator on my 2002 Cadillac DHS and would like to share the ...
    markmnj's Avatar
    markmnj is offline Cadillac Owners Fanatic
    Automobile(s): 1973 Cadillac Hearse, 2002 Cadillac DHS
    Oct 2013
    Hampton Township, NJ
    269
    Greetings,
    I just replaced a faulty air temp actuator on my 2002 Cadillac DHS and would like to share the experience. Not difficult and takes about an hour and a half. Also detailed are the knee bolster removal steps to help you avoid breaking it. I always like to take my time with plastic trim.
    Symptoms:
    Persistent IPM B0429 code
    Intermittent popping sound from dashboard accompanied by incorrect air temperatures for REAR seat passengers.
    Tools -n- Parts Used
    1/4" drive socket set
    1/4" drive Torx bit set (for 1/4" ratchet)
    ACDelco 15-73428 replacement actuator
    Replacement
    1) Disconnect negative battery cable
    2) Remove the passenger side lower kick panel (2 small hex cap screws)
    3) Remove the passenger side knee bolster. No special tools needed. Bolster attachment clips are designed to pull free with a little force. Simply the knee bolster it on the top and bottom on one end and pull straight back toward you. Do the same on the other end then pull the remaining bottom section free in one even step. There are two clips on each end and three or four along the bottom. See pictures of removed bolster showing clip design and mounting hole locations.
    3) Using the 1/4" Torx bit and ratchet, remove the glove compartment CD changer if equipped and the Torx screws holding the glove compartment in and gently pry the plastic glove compartment light/cover off.
    4) Pull the entire glove compartment out toward you. Disconnect the valet switch connector and allow the disconnected light and CD changer wiring to pass through their holes and remain behind. Unlike the knee bolster, the glove compartment will take little effort to pull free once all screws are removed.
    5) Remove the offending actuator. After unplugging, remove the two 5.5mm hex head screws. It may take a little working and pulling to free it from it's shaft. The photo below, shows the actuator as it sits and two arrows indicate the mounting screws.
    6) Installation is the reverse of removal. By the time you are done, the battery will have been disconnected way long enough to allow the HVAC actuators to re calibrate themselves upon power up. After reassembly, re connect the battery, turn the key to "on", HVAC system/blower on and wait a few minutes to allow this. Turn key off, then back on, clear your codes and then it's business as usual.
    eldoedwardo is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado coupe
    Mar 2011
    KCMO
    63
    161
    Re: 2002 Deville Air Temperature Actuator Replacement (others similar)
    Hello, Is that the same component that lets air through thru the left and right side, mine is cold on drivers side warm on passenger side. It started (noticed it) two days after the battery terminal was loose then tightened up. Thanks Ed
    markmnj's Avatar
    Oct 2013
    269
    No, this one only controls the air temperature for the rear or auxiliary air temp as it's called. If you had a loose battery connection, you may have one or more ofyour actuators out of sync. Completely disconnect both of your battery leads and hold the disconnected leads together for 5 or 10 seconds. That will remove any residual power in the system. When you reconect the battery, turn the key to the on position and leave it there for a couple of mins with the HVAC set to "auto". That will allow them to re sync/reset from zero and get things back to normal.
    If that doesn't work you'll need to dig deeper. Scan for codes using your car's built in scanner and repost your question and codes with their definitions in the discussion forum for your car: http://www.cadillacforums.com/forums...ldorado-forum/
    I don't think they intend this section for Q and A, just for how to reference write ups.
    thomashanlon's Avatar
    thomashanlon is offline Cadillac Owners Member
    Automobile(s): 2004 Deville DHS
    Jul 2014
    Bullhead City AZ
    3
    Hello Markmmj, thank you, I just finished doing this on my 2004 DHS. I had a little trouble with the valet switch, I took the switch apart by mistake but was able to get it back together and working. The white connector was back about 10" from the switch and I did not see it. Thanks for the great instructions, Tom Hanlon, new member
    markmnj's Avatar
    Oct 2013
    269
    Hi and welcome aboard :-) I'm glad all worked out
    69
    82,159
    There are about 4 actuators and they are the same for the 2000-2005 Devilles.
    The actuator Mark is talking about is for the rear seat temp control (B0429).
    bones0618 is offline Cadillac Owners Member
    Automobile(s): 2005 deville base
    Aug 2014
    33
    which one is for when the driver side works fine but the passenger side only blows hot air thank you
    69
    82,159
    That would be #15 (RH temp valve actuator)
    http://parts.nalleygmc.com/showAssem...rimLevel=14913
    TheOtherChris and bones0618 like this.
    Aug 2014
    33
    thanks for the diagram but how do i get to this part
    __________________________________________________ _____________
    Good morning, Your last 4 identical questions in "Tech Tips" have been deleted by the site filters.
    Please use the Deville forums and either the GM/Helm service manual set or a subscription to www.alldatadiy.com for instructions on removing parts of the dash, glove box, and HVAC stack for air door service. You might try to Google something like "cadillac forums 2002 deville hvac temperature actuator replacement" or something similar. It's all posted in Tech Tips and in Deville - you just need to find it.
    Tech Tips is for ....... tips. Please read the text in the forum title banner.
    Thanks, CF Staff
    TURBO2's Avatar
    TURBO2 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Deville
    May 2011
    MA
    151
    If ACDelco 15-73428 replacement actuator controls the rear seat temp, then what is the part number for the one that controls the passenger side temp?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,568
    Post #8. Use the Nalley link, go Home, surf to your make, year, model, trim level, system, subsystem. There will be a descriptive text page in addition to the parts blowups.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,558
    Quote Originally Posted by TURBO2 View Post
    the #2 passenger side MIX DOOR ACTUATOR controls both -
    passenger side and rear seat temps -
    PreacherDoug is offline Cadillac Owners Member
    Automobile(s): 2002 Deville
    Jan 2017
    51
    1
    I am having the clicking sounds and can't control drivers side air or heat. It seems all the air is flowing in the dash but not out - and can't get any heat. can't select the vents for drivers either. I think I know which actuator is the problem but it is really tough to get to and get out. ANy help?
  16. #14
    Feb 2006
    56,568
    Welcome Aboard - this forum is Tech Tips - should be stand-alone HowTo info.
    Your fix is in these threads somewhere - reset your forum preferences to "view latest posts/threads first"- that way you see the latest and greatet, not old, dead threads like this one from a few years ago - but there IS actuator replacement info in here - read through this whole thread. Yes, it's a long nuts & bolts problem fix.
    If no joy, post your problem in the Deville forum.
  17. Remove Advertisements
