Hesitating, misfiring, running horrible N* tip..
Results 1 to 2 of 2
Cadillac Tech Tips - How to fix it Discussion, Hesitating, misfiring, running horrible N* tip.. in Item Specific Cadillac Discussion; FYI - last year my 94 STS starting running bad, hesitating and misfiring out of no were, I replaced everything: ...
    Rick94STS's Avatar
    Rick94STS is offline Cadillac Owners Member
    Apr 2005
    New Jersey
    31
    FYI - last year my 94 STS starting running bad, hesitating and misfiring out of no were, I replaced everything: PCM, plugs, wires, O2 sensors, oil & filter, air filter etc..... Nothing I did helped!!
    My mechanic scanned it and came up with nothing useful. He did suggest to try replacing the fuel pressure regulator. As i was beginning to dismantle the top of the intake to get to the regulator I found my fuel injector harness had melted on the top of the trans housing causing two injector wires to short against the trans (ground). I repaired the melted wire harness and tie wrapped it up away from the trans.
    The Car has been running perfect ever since.
    If you are expierincing these simptoms Check your injector harness........
    Take care.
    Raze's Avatar
    Raze is offline Cadillac Owners Enthusiast
    Automobile(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger
    May 2004
    Atlanta, GA
    34
    963
    Re: Hesitating, misfiring, running horrible N* tip..
    Vaccuum leaks in and around the intake, leaking injectors and fuel pressure regulator can also be culprits of rough starts, refer to other posts in this section for more detailed info on troubleshooting and fixing...
