Power Window - Plastic pulley repair
Results 1 to 2 of 2
Like Tree1Likes
  • 2 Post By mleblanc28
Cadillac Tech Tips - How to fix it Discussion, Power Window - Plastic pulley repair in Item Specific Cadillac Discussion; One day, selecting the driver's side door window up, I heard something snap / break. Then the window would go ...
    mleblanc28 is offline Cadillac Owners Member
    Automobile(s): STS-V 2008 Black Raven, STS 4.6 2006
    Sep 2006
    Dallas, TX
    3
    One day, selecting the driver's side door window up, I heard something snap / break. Then the window would go down without any issues, but it had trouble going up.
    Instead of buying a new or junkyard window regulator, I decided to try to repair it.
    A patio door wheel was found, but in was slightly smaller in diameter. The good thing about this pulley, it had a center bearing. So a screw and nut could pinch the pulley.
    The repair.
    Remove the regulator from the car.
    Drill out the aluminum stud. Select a drill size that will remove the stud, but not damage the steel frame. The stud has a shoulder that has a bigger diameter for the pulley, but has a smaller diameter for the frame.
    Found all of the hardware at Home Depot.
    1/4" x 3/4" countersink Phillips screw and nut.
    1/4" washer.
    Prime-line pulley number D-1504 with a grove diameter of 1" and 0.330 thick.
    The original pulley has a grove of about 1.6 inches and .210 inches thick.
    Hope this helps.
    Genius and Genius like this.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,857
    Re: Power Window - Plastic pulley repair
    Nice post. Necessity is the mother of invention.
