Repair Your Rear-Seat Pass-Through Door Latch in a Few Minutes
Results 1 to 7 of 7
Like Tree3Likes
  • 6 Post By basscatt
Cadillac Tech Tips - How to fix it Discussion, Repair Your Rear-Seat Pass-Through Door Latch in a Few Minutes in Item Specific Cadillac Discussion; For the last 7 or 8 years I have learned a whole lot and contributed a little. Now it’s my ...
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,350
    For the last 7 or 8 years I have learned a whole lot and contributed a little. Now it’s my turn to return the favor by showing you how to repair that latch that holds the Pass Through Door closed in just a few minutes.
    In pic 1 you see the latch. Gently, with your thumb press in and down on the cover, see pic 2.
    Attachment 78208 Attachment 78209
    Pic 3 shows the latch with the cover removed, and you can see the spring that is usually missing, causing the whole problem.
    Attachment 78210
    Pic 4 shows what’s under the cover – the black thing is connected to the cable. When the cable is pulled, the black wedge moves to the left, pulling the latch up, releasing the door.
    Attachment 78211
    Pic 5 shows the latch with the replacement spring. The spring sits on a little plastic tip. Pic 6 shows the spring in place.
    Attachment 78212 Attachment 78213
    STEP 7 - refer to pic 3 - shows the latch and spring in place, now just slide the cover back up and you are done.
    you say "OK - GREAT but where do I get the spring?"
    The spring is larger in diameter, a little longer, and a little stronger than a regular ball point pen spring. What I found is that the spring from a “BIC PILOT G-2 05” was the perfect diameter, but a little short, so I stretched it a little to make it a total of 1 inch long – PERFECT!
    I hope this helps someone out.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,350
    Re: Repair Your Rear-Seat Pass-Through Door Latch in a Few Minutes
    double post
    ILoveCaddy is offline Cadillac Owners Member
    Automobile(s): 2001 Seville SLS
    Oct 2011
    5
    I found this forum a few weeks ago and the amount of information is just staggering.
    My pass-thru door has been broken for a while and thanks to Mr. basscatt it is now fixed.
    Thanks basscatt.
    Oct 2011
    5
    I have fixed 2 other caddys using this fixit, has anyone else used it with success?
    johnok2 is offline Cadillac Owners Member
    Automobile(s): 2006 DTS
    Aug 2013
    1
    I have a broken latch but I can't open the attachments in the post.i
    68
    81,889
    They've probably been deleted by Bass.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,847
    They're up in his albums - Community tab ^^^, Albums, rear seat pass-through.
    If the album has gone to History there, click his username, open the profile. Left column, Albums.
  10. Remove Advertisements
