P0717/p056 transmission input speed sensor fix!!
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Like Tree2Likes
Cadillac Tech Tips - How to fix it Discussion, P0717/p056 transmission input speed sensor fix!! in Item Specific Cadillac Discussion; I'm an automotive service technician and I own a 1995 Cadillac STS. I too, had the P056 code come up. ...
    dto
    dto is offline Cadillac Owners Member
    Automobile(s): 1995 Cadillac STS
    Apr 2011
    4
    I'm an automotive service technician and I own a 1995 Cadillac STS. I too, had the P056 code come up. I could replace the sensor myself, but i really don't want to spend 10+ hours trying to replace the sensor.
    After browsing the forums, I stumbled upon this thread, where someone had made a small signal amplifier.
    I decided to build the exact same device. (photo attached)
    When the vehicle was cold, the sensor worked fine. Go in to diagnostics and view PD72. When the vehicle temperature rose, the data disappeared and a DTC would appear.
    I connected the signal amplifier and now it works great. Data is present, when the vehicle is cold and when warm. A big thanks to 'magnum51' where ever he may be.
    89falcon, 89falcon, JK198 and 1 others like this.
    dto
    Apr 2011
    4
    Re: P0717/p056 transmission input speed sensor fix!!
    Materials Needed:
    1 x LM741 Operation Amplifier
    2 x 4 AA battery holders
    1 x 1k ohm resistor
    1 x 100k ohm resistor
    1 x printed circuit board
    miscellaneous materials:
    - wire
    - connectors
    - soldering iron and solder
    The items mentioned literally cost me less then $40 to purchase and i've no past experience with electronics.
    I've provided a schematic and several images to aid, if anyone is interested in building one themselves.
    Rckjaws10 is offline Cadillac Owners Member
    Automobile(s): 1995 Deville
    Aug 2010
    3
    This is very interesting.. I too have the P0717 in my 96 Deville.. Do you have anymore detailed information on how to build, and hook up this device? thanks a lot
  5. #4
    dto
    Apr 2011
    4
    Use the diagrams i've provided. Or I could build it for you, for which i will charge.
  6. #5
    Extortion00 is offline Cadillac Owners Member
    Automobile(s): 1993 Cadillac Deville
    May 2011
    27
    how long did it take you to build this?
  7. #6
    Submariner409's Avatar
    Submariner409 is offline If it won't run, chrome it.
    Automobile(s): 2002.5 F55 STS/65500mi, 2004 F150 SuperCab 4x4
    Feb 2006
    MD Eastern Shore - Kent Island
    75
    46,611
    Quote Originally Posted by Extortion00 View Post
    Once you collect the parts from Radio Shack or an online electronics parts house the build should take a half hour. BUT, practice doing small solder joints FIRST.
  8. #7
    Chino214 is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac Seville SLS
    Aug 2011
    Dallas, Texas, United States
    29
    1
    does anyone have actual pictures of how to actually connect it? i see there's schematics but would like to see actual photo's on how to. Thanks.
  9. #8
    Feb 2006
    75
    46,611
    Quote Originally Posted by Chino214 View Post
    Post #1 & #2. The only thing you would see on the underside of the pre-printed PCB is solder dots.
  10. #9
    May 2011
    27
    does this also work on code p0717??
  11. #10
    Johnny8519 is offline Cadillac Owners Member
    Automobile(s): 1996 SLS
    Aug 2011
    41
    1
    I have the Code P0717. My situation seems to be totally differnt the all of the ones I see posted here. The Service engine light as well as the service transmission. comes right away as soon as I start the car. It doesnt seem to ever go out, hot or cold. When I clear the code it goes out. It wil stay out until I drive about 75 ft. Can the Signal Amp fix my problem? I did find some similar things. There was a alot of tranny fluid inside the connector. I cleaned it. Did not help.
  12. #11
    dto
    Apr 2011
    4
    It's still working like a charm.
  13. #12
    rolexcomm is offline Cadillac Owners Member
    Automobile(s): catera
    Jan 2010
    39
    quick question, is this device supposed to tap into the red/black wire leaving it intact or is it supposed to go in between the sensor and pcm by cutting said wire??? also is there any situation in which this device wouldn't work??
  14. #13
    Atrayyu is offline Cadillac Owners Member
    Automobile(s): 95 Eldorado
    Nov 2011
    Hey all,
    made an account so I could post, been following for a while though.
    Couldn't you substitute a a 12v source from the car instead of using 8 "AA" batteries?
    then you wouldn't have to worry about the batteries going bad right?
    I am about to make one of these for a friends car, because I really don't want to go through the hassle of dropping the motor/tranny down to fix it for him.
  15. #14
    Nov 2011
    Quote Originally Posted by rolexcomm View Post
    from dissecting the diagram.... you have to cut the wire, and place the device "in line", can't just tap into the wire and run it in "parallel", must be ran in "series"
    I have not made one yet, but that's just the operation of any signal amplifier... hope it helps.
  16. #15
    jmcl40 is offline Cadillac Owners Member
    Automobile(s): 1996 Seville sts
    Dec 2011
    74
    1
    Did you build the amp and if so did it work for code p0717 ? I have same problem code at all times but have run car for several thousand miles with no apparent transmission problem.
    Thanks
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
