P0410 Secondary AIR
Results 1 to 2 of 2
Cadillac Tech Tips - How to fix it Discussion, P0410 Secondary AIR in Item Specific Cadillac Discussion; I just fixed this problem and wanted to put the info out there. Mine was not the AIR motor, I ...
    87gnturbosix is offline Cadillac Owners Member
    Automobile(s): 2003 Deville
    Jun 2009
    1
    P0410 Secondary AIR
    I just fixed this problem and wanted to put the info out there. Mine was not the AIR motor, I could hear it running every cold start. I checked the solenoid and it was working. I then checked each check valve with a vacuum pump and found the rear one not pulling a vacuum. I plugged the vacuum hose going to the rear check valve and the code went to P1415 (AIR system bank 1). Replaced the valve, no more check engine light.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,581
    Re: P0410 Secondary AIR
    Good catch. Thanks for the feedback.
