How to fix 97-99 Deville turn signal flasher
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By wallace902
Cadillac Tech Tips - How to fix it Discussion, How to fix 97-99 Deville turn signal flasher in Item Specific Cadillac Discussion; Here is how to fixed my 99 Deville turn signal flasher.Use simple tool one flat screwdriver and new turn signal ...
    wallace902's Avatar
    wallace902 is offline Cadillac Owners Member
    Automobile(s): 2006 dts,2000 sts,99 deville,
    Jan 2004
    Toronto,ontario
    51
    54
    Here is how to fixed my 99 Deville turn signal flasher.Use simple tool one flat screwdriver and new turn signal flasher part number 3548813 or get it from junk yard (free).
    TigerDude33 likes this.
    mitw44 is offline Cadillac Owners Member
    Automobile(s): 1994 Sedan Deville 4.9V8 1998 Sedan Deville Northstar V8
    Jul 2009
    Oklahoma
    52
    9
    Re: How to fix 97-99 Deville turn signal flasher
    Nice writeup and pics!. I wonder if the flasher for the 94 Deville 4.9 is in the same location. I spent 30 minutes laying on the floorboard looking for it to no avail. Anyone ever changed a flasher on a 94 and can comment?
    Thanks
    wallace902's Avatar
    Jan 2004
    Toronto,ontario
    51
    54
    I got my flasher from 94-96 deville.They are the same location.
    jhandley13 is offline Cadillac Owners Member
    Automobile(s): 1998 Deville
    Nov 2009
    1
    Very helpful...thanks.
    z1r
    z1r is offline Cadillac Owners Member
    Automobile(s): 99 deville
    Nov 2010
    51
    1
    very nice , thanks a million. My 86 year old dad will thank you as well !!!
    dukester is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2008
    96
    Hello,
    Do I have to be concerned with breaking any plastic or tabs when prying out the dimmer switch / gas door trunk release panel?
    How difficult is to locate and remove the flasher?
    How difficult is to re-connect the flasher with the metal tab to correct location?
    In advance, many thanks . . .
    rodnok01's Avatar
    Feb 2012
    NC
    6,651
    The panel just pry's out, a little on each side at a time using a interior pry tool. The flashers easy to replace, small tabs like all the other stuff. Take your time and you won't snap them off either. Flashers under drivers side dash.
  10. Remove Advertisements
