Courtesy of MarkC
Removal Procedure
Disconnect the negative battery cable.
Remove the accessory drive belt. Refer to Drive Belt Replacement .
Remove the upper front bolt.
Raise and suitably support the vehicle.
Remove the front engine splash shield.
Remove the radiator support access panel.
Loosen the rear generator bracket from the engine.
Remove the top bolt.
Remove the front lower mounting bolt.
Remove the lower rear mounting bolt.
Remove the upper rear mounting bolt.
Remove the duct from the back of the generator.
Disconnect the following electrical connections:
Regulator
Battery output
Heated windshield (if equipped).
Remove the front generator/ A/C bracket.
Rotate the generator and remove.
Installation Procedure
Install the generator.
Install the front generator/ A/C bracket.
Connect the following electrical connections:
Regulator
Battery output Tighten
Tighten the battery output cable to 20 N·m (15 lb ft).
Install the duct to the back of the generator. Align the duct to the generator black duct.
Install the upper rear mounting bolt. Tighten
Tighten the upper rear mounting bolt to 47 N·m (35 lb ft).
Install the lower rear mounting bolt. Tighten
Tighten the lower rear mounting bolt to 47 N·m (35 lb ft).
Install the front mounting bolt. Tighten
Tighten the front mounting bolt to 47 N·m (35 lb ft).
Install the rear generator bracket bolt to the engine. Tighten
Tighten the bracket mounting bolt to 47 N·m (35 lb ft).
Install the upper front bolt.
Install the radiator support access panel.
Install the front engine splash shield.
Lower the vehicle.
Tighten the upper front bolt. Tighten
Tighten the upper front bolt to 47 N·m (35 lb ft).
Install the accessory drive belt. Refer to Drive Belt Replacement .
Connect the negative battery cable. Tighten
Tighten the negative battery cable bolt to 15 N·m (11 lb ft).
Removal Procedure
Regulator
Battery output
Regulator
Lower the vehicle.
