TB and IAC (idle air control) valve cleaning - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 49
Like Tree18Likes
Cadillac Tech Tips - How to fix it Discussion, TB and IAC (idle air control) valve cleaning in Item Specific Cadillac Discussion; Ern, Most of us think you have CKP problems - but if you want to clean the IAC, in your ...
  1. #31
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,264
    Re: TB and IAC (idle air control) valve cleaning
    Ern, Most of us think you have CKP problems - but if you want to clean the IAC, in your car it's held by 2 Philips or Torx machine screws into the left (front) side of the TB. The screws are easy to drop - careful. Remove the IAC and clean the top hat plunger with a bit of TB spray but be careful not to let much/any run into the solenoid body itself. Also clean out the bore and passage in the TB with a fuzzy pipe cleaner - packs of them from craft stores. Rub a drop of engine oil on the O-ring and replace the IAC.
    DJLogsdon likes this.
  2. #32
    BigErn23's Avatar
    BigErn23 is offline Cadillac Owners Member
    Automobile(s): 2000 Cadillac Seville STS, 2007 Cadillac Escalade
    Sep 2013
    Chicago
    37
    86
    Thanks for the illustration.
    ....not sure about the butt plug, though.
    I figured I'll give it a shot. I understand its likely going to come down to the CKP, but I wont have time for that for a week or two.
    But thanks for all your time/help. I'll check the IAC tomorrow just to see if it makes any difference.
    If it is CKP for certain, think that would cause poor idle at standstill?
    Anyway.....if none of this works I'll just get a couple of them chrome fender louvers and be done with it.
  3. #33
    68
    82,081
    My bad CKP sensor never caused an idle problem and I can't recall ever hearing of that. When they go bad they cause a longer than normal crank time and/or a stall at idle or sometimes a stumble or stall at cruise.
  5. #34
    DEVILMANMN is offline Cadillac Owners Member
    Automobile(s): 2000 Deville
    Jun 2012
    5
    On my 2000 deville base model the vacuum port in this picture has a plug on it. I see in his picture it goes to something?
  6. #35
    Feb 2006
    56,264
    Of course it does - remove the beauty cover and trace the plastic line - or are you talking about the MAP sensor on top ?
    IF your Deville has an AIR system, that port is the vacuum source for the two check valves. One on the right (rear) cam cover, the other near the water pump cover.
    (A.I.R. - the blower and hose system that supplies fresh air to the exhaust manifolds for some seconds after cold start in order to quickly light off the cat. The number of gray relays clipped to the passenger side strut tower - 0, 1, 2 - tells you if you do or don't have the emissions system installed.)
  7. #36
    01SevilleSTSSpeeder's Avatar
    01SevilleSTSSpeeder is offline Cadillac Owners Member
    Automobile(s): 2001 Seville STS
    Dec 2013
    21
    8
    Hi there, I read first page and cleaned my throttle body and iac best of my ability, only had carb cleaner and tooth brus and shop towels, went to start car after all was cleanecleaned and now it high idles at like 1500 or even 2000 rpms, what happened, I'm not putting it in gear like that, that would deviate my transmission, it has 224000. The only reason I wanted to clean iac was cause it had rough low idle and misfire that occurs only at idle, hit gas and runs on all eight whole time not idling, but that's besides point now. How do I fix this, New/used iac, they have them on ebay for 15 bucks aftermarket? Thoughts and ideas. Need my car and can't drive it like that,
    p.s., silly me being cureous sometimes, I pushed and pulled on valve while cleaning it to see if it would move more freely, not knowing what I was getting into, put it in clamped everything back up, over rev, shut down, remove, figure if it sticks out and revs up, we'll I'll just push it in and idle down, put it back in and start, revs higher and more erratic, PLEASE HELP, loved my car till iidle issues started.
  8. #37
    68
    82,081
    Quote Originally Posted by 01SevilleSTSSpeeder View Post
    That may be your problem. You could try pulling both battery cables and touch them together. If that doesn't help, you might try the idle learn procedure. If all else fails, you may have to replace the IAC valve.
    Have you pulled the DTC's?
  9. #38
    Dec 2013
    21
    8
    All I have is rough idle, with random misfire code, got it scanned, p0303, but car only shows p0300 and I know car wont show specific cylinder, but have replaced iac valve just cause was 15 bucks on ebay. Now it idles bit better, but also cleaned egr valve, inside of throttle body and removed and reinstalled tps, now it idles better but while warming up after 1100rpm high idle it surges till fully warm and idles around 650-700 but sill rough. Put it in gear and of course idle drops to about 550-600 and check engine light starts flashing, idle gets rougher, hit gas and stops misfiring and runs on all eight, can floor it and it goes like it should. So dunfounded, don't know what to do next. how do I relearn idle procedure, and what does touching cables together do? Also with removing and reinstalling tps it didn't go back on exactly how it was, slightly turned a tad. now throttle is touchier and when its warming up and go to hit gas, it wants to take off a bit on its own like it revs up, but once warm it acts normal. Thinking I might need to replace tps, but hat wont fix idle issue. And wouldn't i have to have tps relearn or something.But car hast been right since idle issue started. At least I can drive it now. Any more advice, lol?
  10. #39
    Feb 2006
    56,264
    For that car the
    TPS relearn is - turn the key ON (no start) for one minute, turn it OFF for at least 30 seconds.
    IAC relearn is - START and idle for 15 seconds, engine OFF for at least 15 seconds. Restart and check idle speed at about 650, in P, N, or D and with A/C ON or OFF - all 650 rpm.
    (2002 Seville service manual set, powertrain management, fuel/air and sensor(s))
  11. #40
    68
    82,081
    Think of it sort of like a computer reboot.
  12. #41
    teeluv31 is offline Cadillac Owners Member
    Automobile(s): 2002 Deville
    Sep 2014
    eastern NC
    6
    Didnt drive my car for about 2 days because of low idling issues. So cleaned the TB and the IAC port. (Have cleaned the TB before but not the IAC or port) When I took the IAC out the plugger was wide open. I could see the spring and all. So is my IAC bad?
  13. #42
    Feb 2006
    56,264
    Re: Cleaning the TB & IAC valve on a 2000+ Northstar
    Here's what your 2002 IAC should look like. The black "top hat" pintle is attached to a motor that moves it in and out to control airflow around the throttle blade.
    RockAuto - and not cheap. Maybe there are a few decent junkyards in your area - any 2000 - 2003 Northstar engine.
  14. #43
    markparrish16's Avatar
    markparrish16 is offline Cadillac Owners Member
    Automobile(s): 2002 DTS
    Aug 2015
    None
    22
    6
    Quote Originally Posted by mtflight View Post
    the pics are live, try refreshing?
    hi, so you didn't use any throttle body cleaner?? just the crc motor cleaner??
    how often should i clean these?? mine has the same exact problem right now.
  15. #44
    Feb 2006
    56,264
    Depends on the year of the engine. The pre-2000 TB and passages gets filthy pretty quickly due to the location of the PCV dirty air line - at the manifold vacuum tap right at the throttle blade. 2000 and later stay cleaner longer - the PCV dirty air line goes into the intake manifold at the passenger end. Trace it out.
    I last did mine in 2010 - still squeaky clean today.
  16. #45
    68
    82,081
    I'd recommend doing it as an annual spring cleaning. Once a year makes it a :15 spray and wipe project.
  17. Remove Advertisements
