1993 Fleetwood: Broken Tabs on Back-up Light
Results 1 to 2 of 2
Cadillac Tech Tips - How to fix it Discussion, 1993 Fleetwood: Broken Tabs on Back-up Light in Item Specific Cadillac Discussion; The tabs broke off the back-up light on my 1993 Fleetwood. The repair would work the same for many other ...
    vanagon40 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Sep 2007
    8
    The tabs broke off the back-up light on my 1993 Fleetwood. The repair would work the same for many other projects.
    I removed the light and cleaned the broken tabs. I then cut credit cards to fit into what was left of the old tabs with a large area extending beyond the tabs.
    I attached the credit cards with duct tape. Then, JB Weld to the rescue. I placed a good amount of JB Weld on the back side of each tab. For reinforcement, I buried a 1/4" washer in the JB weld.
    Twenty-four hours later I removed the tape and credit cards. I filed off the excess JB Weld with a rasp. I also used a wood chisel to flatten the face of each tab, but I doubt that it was necessary.
    I drilled 3/16" holes in each tab and it bolted right back on with #8 sheet metal screws.
    Good as new.
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    Re: 1993 Fleetwood: Broken Tabs on Back-up Light
    Congrats on fixing the tabs! That`s being really creative-----credit cards and JB weld-----fantastic!
