Dexron-vi Gm Tsb
Results 1 to 3 of 3
Cadillac Tech Tips - How to fix it Discussion, Dexron-vi Gm Tsb in Item Specific Cadillac Discussion; Effective immediately GM has released TSB 04-07-30-037D dated 11/21/07 concerning the new DEXRON-VI synthetic automatic transmission fluid. The TSB basically ...
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,553
    Dexron-vi Gm Tsb
    The TSB basically states that all current and past GM passenger cars and some trucks will now use DEXRON-VI instead of DEXRON-III for warranty, fluid change, and routine level maintenance. All GM facilities will convert their transmission change/flush machinery to DEXRON-VI. The new fluid has been determined to be fully compatible with DEXRON-III in any quantity.
    Full details, all models affected and text in www.alldatadiy.com .
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    Re: Dexron-vi Gm Tsb
    Quote Originally Posted by submariner409 View Post
    Thanks for the info!
    oldworld is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 Escalde, 2007 DTS
    Nov 2007
    Lancaster County, PA
    532
    There is a new update..same number but ends in "E"
    Does anyone have access to this tsb. Hate to spend $30 to sign up just for one tsb.
    THANKS
