Results 1 to 2 of 2
Thread: 2004 Cadillac DeVille DHS/Base Center Console Arm Rest Replacement
    ophedian is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2007
    40
    Post 2004 Cadillac DeVille DHS/Base Center Console Arm Rest Replacement
    These steps apply to the 2004 DeVille DHS and Base Model. In General 2000 - 2005 DHS and Base Models should be the same. I am posting this because someone was asking how much time is involved in replacing the Armrest.
    Tools you will need:
    1: Torx #27 bit:
    Project Time:
    10 Minutes
    Directions:
    Because we are not working on any electrical parts in this section, battery power does not need to be removed.
    1) Move the front seats as far forward as they will go using the Seat controls.
    2) Locate the two finishing plugs on the side of the Center Console
    3) Rotate the plugs counter-clockwise to loosen and remove.
    4) Using a Torx #27 Bit, unscrew the two screws, one on each side of the console.
    5) Rotate the console approximately 45 degrees and pull it towards the roof maintaining the 45" angle. [Note: the hinges in the console are notched at 45 degrees to allow the console pivot rods to slide out]. If the armrest sticks, pull on the side of the center console to give the armrest pivot rods room to slide out.
    You are done!!
    Feb 2007
    40
    Re: 2004 Cadillac DeVille DHS/Base Center Console Arm Rest Replacement
    For some reason, the image link for steps 1 and 2 did not come over.
    Armrest Screw Locations Console Images
  • You may not post replies
