How to: more than quadruple the range of your car remote(fast & free too) - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Cadillac Tech Tips - How to fix it Discussion, How to: more than quadruple the range of your car remote(fast & free too) in Item Specific Cadillac Discussion; Weister42: I'm going to try the antenna extension trick you posted as my RKE is pathetic too. I can be ...
  1. #16
    greg-sls's Avatar
    greg-sls is offline Cadillac Owners Enthusiast
    Automobile(s): 1997 SLS
    Jun 2007
    Phoenix
    550
    Re: How to: more than quadruple the range of your car remote(fast & free too)
    Weister42: I'm going to try the antenna extension trick you posted as my RKE is pathetic too. I can be right up to the car and press unlock over and over turning the darn remote in all directions before it works. Yes - the batteries are new too. My 91 Eldo was fantastic and one press 40 feet away always worked.
    I also want to see if I can access the "box" from the trunk. There is a felt panel that easily removes revealing all kinds of components hidden behind the rear seat. That would be easier than taking the back seat out.
  2. #17
    nicbrown is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2007
    13
    btw can someone let me in on the forehead remote thing? I don't get it
    Answer:
    The oral cavity in your skull amplifies the signal.
  3. #18
    eyekandyboats.inc's Avatar
    eyekandyboats.inc is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS(140K), 2000 ETC(284K), 1990 allante( 80K)
    Mar 2007
    Tottenham, Ontario,Canada
    1,914
    just press it to your forehead and it will have more range.
  5. #19
    N0DIH's Avatar
    N0DIH is offline Cadillac Owners Master
    Automobile(s): 94 Fleetwood Brougham
    Aug 2004
    Rockford, IL
    50
    7,531
    Takes too many brain cells away and I might forget to take it off my forehead.....
  6. #20
    TSS's Avatar
    TSS
    TSS is offline Cadillac Owners Connoisseur
    Automobile(s): 07 Lade & 06 SRX (Gone); 2010 Enclave CXL; 2010 MKS Ecoboost
    Jun 2006
    3,673
    Quote Originally Posted by eyekandyboats.inc View Post
    any one try this out yet ( head to remote )
    Yes it works. I have been amazing people with it for years. I just hold it to my temple (like I am shooting myself with it). I Used to do the chin, open mouth thing, but found it was the same as the temple (which does not draw as much attention). Both work though.
  7. #21
    99esteees's Avatar
    99esteees is offline Cadillac Owners Enthusiast
    Feb 2006
    Indiana
    32
    873
    lol the famous meat mod.
  8. #22
    MisterBlue is offline Cadillac Owners Fanatic
    Sep 2007
    272
    Don't know why, but my '98 would only work from about 30 feet, and you had to be "broadside" to the vehicle. My '05 will lock/unlock from 250-300 feet (easily), and the "panic" button will work even further!
    The biggest asset to this capability is how easy it makes it to find the car in a large parking lot or garage.
  9. #23
    hthorn is offline Cadillac Owners Member
    Feb 2008
    47
    The remote-to-the-head trick is not fiction--it works! I have to do this with a gate opener. It's nothing to do with the car itself, but I've found holding the fob up to my temple increases the range enough to get the gate to open. Before I was advised of this trick I used to have to hold the fob 3" from the receiver's antenna. Even after I replaced the battery, of course!
  10. #24
    keelerdr is offline Cadillac Owners Member
    Automobile(s): 1997 Deville D'Elegance
    Sep 2009
    Southeastern PA
    43
    Thanks for the tip (the actual extension of the receiver's antenna by adding wire to the box behind the seat)!
    The mouth/temple thing works because the transmitter is using you as an antenna to send the signal. I learned the chin thing a while back from a friend who used to valet cars. Same principle when you touch an FM antenna on a boom box...it will use you as an antenna (on the receiving side this time, rather than the sending side like the key fob was using) to improve reception.
    Not sure of the health effects of either...but who cares.
  11. Remove Advertisements
